SOURCE: I have a Hampton Bay Midili fan which I just
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
SOURCE: How to remove a Hampton
Hi.
Take the screws out of the sides of the top cover plate...drop it down, then unhook the wires and remove the screws holding the mounting plate...
heatman101
SOURCE: My Hampton Bay ceiling remote
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote.
Once you get a new remote you have to again make sure the dip switches are in the same position.
Paul
SOURCE: Receiver on Hampton bay the
Hi, First you need to check the housing mounted to the ceiling as the transmitter is there. Next you have to try and match it to a new remote or look for some number on the transmitter. However you can usually buy a new remote and transmitter for 30 bucks and just swap out the transmitter. This will be helpful in case you cannot match the numbers. They come labelled and r pretty easy to install. Please accept the solution if it's helpful. Do get back to us for any further query. Thanks for contacting fixya.com
SOURCE: I need to replace the
You can buy a fan remote at Home Depot, Lowe's,or Menard's basically any one of the big box stores. If they do not have the one used with your fan,you buy a universal remote. Follow the instructions in the box make sure you shut the power off as you may get shocked or burn up he control
Testimonial: "."
