Question about RCA HD52W56 52" Rear Projection HDTV
The volume on my tv goes up and down and the menu pops up on its on and it randomly changes the channels
  • RCA Master
  • 8,617 Answers
The small signal board needs replacement.nVery common problem. You can get a small signal board from www.tvrepairworld.com
Posted on Aug 08, 2010
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
I have a 47lg70 ug 47" tv. The set up menu randomly pops up. It then start scrolling through some of the other menues. No changes are ever made. Also, the volume will not adjust, none of the contols on...
You will need to replace the Sub PCB. Its about a $50 fix if you do it yourself.
You can find the part here.
Its part 510.
This circuit board controls the volume, channel, menu buttons, ect.
Sep 27, 2010 | LG 47LG70 42 in. LCD TV
Cannot change channel, volume, or select menu. will not accept input from remote anymore. you press menu, on the tv, nothing then you press volume or channel and menu pops up but as soon as any key is...
If the buttons do something, but not what they are supposed to do.....By chance are you using a universal remote (replacement for your original)? If so, the codes for the remote need to be re-set for use with your TV. Hope this helps.
Apr 09, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Aug 22, 2007 | RCA P52929 52" Rear Projection Television
RCA HD52W56 52" Rear Projection HDTV Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
