Question about Gateway MX3210 Notebook
Processor fan stopped working. Replaced fan, still in-op.
    President:
  • 1,768 Answers
This is a board issue. the power to the processor fan pins has failed this may be due to power supply be faulty. This is usually a main board replacement or repair.
Posted on Aug 07, 2010
Dell Inspron 1000 processor fan stopped working. Is there an easy fix ???
The only easy fix would be to purchase a laptop tray that includes fans like those sold at OfficeMax and it would save you the trouble of having to open the laptop and maybe keep it cool enough to work for a while without it shutting down.
Aug 20, 2014 | Dell Inspiron 1000 Notebook
167 bios
To troubleshoot processor issues, follow these steps and test the processor after performing each one:
Notes:
  • If either the system board or processor have been replaced, reflash the BIOS to the latest level before proceeding.
  • Some computers allow the fan to stop spinning. This is not a malfunction. The fan should start spinning as the system heats up.
  1. Ensure the latest BIOS code is installed. This will correct any 167 POST errors for the Intel microcode update and "176 No Processor CPUID" post errors.
  2. Reseat the processor and the heat sink
    Note: Do not touch either the processor or system board contacting surfaces. These can be extremely fragile and bent pin damage due to touching is not covered under warranty.
  3. Verify the processor fan operation is not blocked by cables or other hardware.
  4. Verify that any replacement processor is the correct architecture for the system.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | IBM NetVista PC Desktop
After using our Toshiba l305d-s5934 computer it shuts down from over heating , this problem has gotten worse lately ! We did a defrag today , but that didn't help ! We bought a lap top fan for it but it...
hi
over heating cause the processor stop working, remove you processor and check at the back of the heatsink there is paste between heatsink and processor try to put some, and check the heatsink and processor seated properly. the fan check it also.
thanks
inform me if still didn't work.
thanks
Nov 22, 2010 | Toshiba Satellite L305D-S5895 Notebook
Hp 6735s turnin of itself and is overheating
To avoid laptop overheating, follow the information from this link.
Oct 26, 2010 | HP Compaq 6735s Notebook
Sir, I have a Dell optiplex GX110. At the motherboard there is a long brown slot in which a board of 4 expansion slots has been pluged. The first problem was that I had removed the heat sink from the...
When you inserted a test probe into the slot and you saw a spark, then you have short circuit a component on the motherboard and have done a major damage to the motherboard.
You need a new motherboard, most desktop cases have standard mounting holes, you may be able to purchase a motherboard from other manufacturer to fit in the Dell.
Oct 09, 2010 | Dell Optiplex GX110 (2909T) Motherboard
One of my fans has started making noise, how much time do i have to replace it? Am I right in thinking that it making noise that it needs to be replaced?
fan noises are usually caused by worn out fans. but can be also caused by IDE/power cables hitting the fan blades. you will have to open up the computer to see where the noise comes from.
if it is a faulty fan, replace it sooner than later as it will get louder and louder. then stop making noise all together when the fan fails.
Dec 09, 2009 | Dell OptiPlex GX270 PC Desktop
Turns itself off & gets hot -don't think fan is kicking on
Since you do not hear the fan anymore I would start by opening up the case and seeing if power is going to the fan and make sure any connectors for it have not come loose. If the connectors are still hooked up chances are the fan is shot and needs to be replaced.
If you are not familiar with working around electronics and parts under power I would highly suggest you have some one who is familiar with this do it.
May 06, 2009 | Computers & Internet
Fan stopped
If the fan has stopped, then the processor will overheat. Most vendors have protection so that a non-working fan is detected and the unit will not power up with detecting its rotation. Seems like a repair shop job I'm afraid.
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Gateway MX3210 Notebook Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
