Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet 1810 changed the oil now it starts but will not move forward or back.. model-149650100 serial-790434
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
  • 202 Answers
SOURCE: how do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Posted on Jul 08, 2009
SOURCE: cub cadet starts but won't move forward or reverse
What model? I have a 1554, that I just took to the dealer, for repairs, for the same thing. The motor starts, the blades engage and cut, it just stopped moving forward, or reverse. If I remember, I'll get back on here and let you know, unless you already know?
Posted on Apr 22, 2010
SOURCE: how do i reset the change oil light on a 1040 cub
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Posted on Sep 01, 2010
  • 203 Answers
SOURCE: Cub Cadet LT1045 oil light
I am thinking that might be a notice to change the oil, which is only for notification purposes. Check your owners manual. There may be a procedure to reset the timer when you change the oil.
Posted on Sep 04, 2010
Cub Cadet GT 2000 garden tractor will not move forward or reverse after I just changed the hydraulic fluid and filter, it ran fine the day before doing this????
My first guess is that you have air inside the transmission. Most transmissions have a purge procedure to get the air out after an oil change. Please look in your operator's manual for the procedure.
Feb 20, 2017 | Cub Cadet Garden
My cub cadet LT 1050 wont move forward or back but starts and the PTO will run?? need help.
make sure your tranmission is engaged if still not working change fluid and filter if not can you hear pump loudly when you try to move it if so be ready to buy a new pump
Aug 14, 2013 | Cub Cadet Garden
Cub Cadet 2166 tractor, changed transission filter and oil
did you check to see if your belt was in good shape and if the hydro relef was in
Apr 14, 2012 | Cub Cadet Garden
I have a cub cadet model 1420 with hydrostatic drive that will not go forward or reverse. The drive belt is moving and the hydrostatic unit was replaced 3 years ago. I still have to engage the lever to...
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Sep 28, 2010 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Cub cadet starts but won't move forward or reverse ? what should i try to do?
Apr 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Jun 16, 2009 | Garden
Transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Mar 23, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
127 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
