Question about MSI P43 NEO-F INTEL P43 LGA775 ATX Motherboard
I wish to know what compatible memory for msi lga775 motherboard, ddr ram?
  • 2,841 Answers
DDR2 SDRAM.
Posted on Aug 07, 2010
I have intel 915 GLV mother board and 256mb ram, now i want to upgrade my ram to 1GB. please let me knw what kind of RAM i need to buy along with its image details.
Intel Desktop Board D915GLVG - motherboard - micro ATX - LGA775 Socket
Max Supported Memory 4 GB Supported RAM Technology DDR SDRAM Supported RAM Speed 400 MHz, 333 MHz Supported RAM (Registered or Buffered) Unbuffered RAM Features Dual channel memory architecture
Aug 10, 2011 | Intel D915GLVG Motherboard
I have a (mx-6378x-l) k0302002574. What is the amount and type of ram that it will support?
See: http://www.motherboards.org/mobot/motherboards_d/MSI/MS-6378X-L%2528MS-6378%20V.3%2529/
Front Side Bus 266/200 Mhz
Memory Type SDRAM Memory Channels Single Maximum Memory 1GB
Memory Type SDRAM
Maximum Memory 1GB
So, it's the older PC133/PC100 RAM, not the newer DDR RAM, nor the newest DDR2 RAM,
that will be compatible with the 266 (2 times 133) or 200 Mhz (2 times 100) speed of the bus.
Dec 20, 2010 | MSI MS-6378X-L Motherboard
How do i read the motherboard to see what board i have
The Manufacturer of the mother board is MSI and details are as follows:
Manufacturer Part # :K9MM-V
Product Type :Motherboard
Form Factor/chase: Micro ATX
Chipset Type :VIA UniChrome Pro K8M800 / VIA VT8237R Plus
Multi Core Support :Dual Core
Max Bus Speed :800 MHz
Socket Type 0 ( 1 ) :- Socket AM2
Compatible Processors : Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
It supports 64 Bit Processor
Multi Core Support :Dual-Core
Its Supports RAM Technology: DDR II SDRAM
RAM Installation : 0 MB / 2 GB (max)
Supported RAM Speed :PC2-4300, PC2-6400, PC2-5300
RAM Features :Two DDR Channels
Video Memory :Shared video memory (UMA)
Audio Codec :Realtek ALC655
Sound Output Mode : 5.1 channel surround
Expansion Slots Total (Free) :1 processor - Socket AM2
You can addin RAM of :2 memory ( 1.8 V ) - DIMM 240-pin
PCI :3 PCI ( 3.3 V/ 5 V )
Storage Interfaces
Additional Connectors : 4 x Hi-Speed USB
Dec 21, 2009 | MSI K9MM-V Motherboard
Upgrade
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565.
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
My msi pm8pm mb doesn't accept 1gb memory pc667 its accept only 256mb pc533, what i need to do to accept 1 gb memory, pls help me!!!!!! tnx!!
Your MB can take a max of 2 GB RAM. And it has to be DDR SDRAM. So, please ensure that it is compatible. Then only would it accept the RAM SIMM else it may damage the mother board. or the RAM itself.
Oct 13, 2009 | MSI PM8M-V Motherboard
How mutch RAM does "Motherboard MSI PM8M3-V (MS-7211 v1.x) Micro-ATX" supports
Spec sheet shows you can run 2GB of PC2700 DDR RAM (DDR-333), or PC3200 DDR RAM (DDR-400); http://www.superwarehouse.com/MSI_PM8M3-V_Micro_ATX_Pentium_4_Motherboard/PM8M3-V/ps/727805
MSI also provides a list of tested memory for the board;
http://www.msi.com/uploads/test_report/TR10_234.pdf
Hope you find this helpful!
Mike
Oct 12, 2009 | MSI PM8M3-V Motherboard
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
Pc5300 on pc3200 slot to upgrade msi 845gvm-v
PC5300 or more correctly "PC2-5300" and can work in a system that has "PC2-3200" RAM, and if mixed, they will operate at the speed of the slowest module. "PC-3200" RAM, however, is not compatible. PC-3200 is DDR SDRAM, having 184 pins. PC2-3200, and PC2-5300 are DDR2 SDRAM, having 240 pins. DDR and DDR2 modules are the same length,
but the pins on DDR2 are smaller and the keying notch is in a slightly different position.
You need to get the replacement ram all the same type ie - DDR or DDR2
And yes your motherboard should accept 2GB max
Jun 15, 2009 | MSI 845GVM-V (MS-7057-010) Motherboard
Increasing Memory Ram
According to the memory configurator at www.crucial.com your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
Look here for more information.
http://www.crucial.com/store/listparts.aspx?model=MS-6390
Aug 28, 2008 | Intel Motherboard
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
MSI P43 NEO-F INTEL P43 LGA775 ATX Motherboard Logo
61 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
