Question about Whirlpool Dryers
Heating elements gets very hot - Whirlpool Dryers
    President:
  • 2,702 Answers
Check the air flow into the unit if clear and the outlet pipe is clear as well the dryer need to breath freely or it over heats till the thermol cut out shuts it off,,, but this may kill it off all together
Posted on Aug 07, 2010
We can't get our hot tub to heat. The heater light comes on but the heater still won't heat.
heating elements are resistors that get hot
one end will have 115 volts but the other end should be considerable less because the resistance of the heating element drops the voltage
if you used a ohm meter you should be reading a resistance of 500-1000 ohms for a good heater element but with your readings , there will be no resistance so the element is faulty
Apr 06, 2017 | Element Water Heaters
What else can I try, my Intertherm water heater is not heating water off the lower element?
I should like to hope I have your answer.
If yours is like most U.S. model, it is called a 220 volt unit.
That is not really 220 volts, it is really 2 separate 110 volt units.
What that means is, there are actually 2 separate 110 volt hot wires to the water heater, usually one hot wire is black, and the other hot wire is red.
One is for the upper heating unit, one is for the lower heating unit. Perhaps your lower unit has blown the circuit breaker for that line.
I mean the circuit breaker in the main fuse box/circuit breaker box.
Did you test the lower wiring to see if the hot wire is hot?
If it is hot, be sure to test the ground wire, and also the wiring between the bottom and the top of the heater inside it.
God bless your efforts.
Jan 04, 2018 | Water Water Heaters
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
see this causes and fix it. God bless you
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Sep 28, 2012 | Fisher and Paykel Dryers
The water in my dishwash is not getting hot dose the cord that's in the bottom of sopose to get hot?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jun 16, 2011 | Dishwashers
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
No hot water
Check your panel breaker to make sure its on. If it is, it's possible that the upper thermostat or element has burned out in your heater.
First remove the upper thermostat cover plate and check the high limit switch button. If it has tripped, press it to reset it.
Check for power at the input terminals of the upper thermostat. (usually marked L2 and L2) If no power is present then check your circuit breakers or wiring to the water heater.
If there is no hot water then the upper thermostat should be applying power to the upper heating element. Check for voltage at the upper heating element. If there is power at the heating element but the element is not getting hot then the heating element needs to be replaced.
If there is no power at the upper heating element then the upper thermostat needs to be replaced.
Hope this helps.
Mar 14, 2010 | Welding Tools
Gibson modelGSE746RFS1 does not get hot. The tub turns and all the control seem to work correctly, but it does not get warm or hot. I am not sure how to get to the heating element.
could be the heating element, mine was a 20$ sensor screwed to the side of the heating element,dont remember the name of the part but it burns out when got too hot ,under the bottom of unit
Jun 16, 2009 | Dryers
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
