Question about Samsung WF328AA Front Load Washer
Detergent dispenser is filling with water and water is running out of the dispenser. cannot see anything wrong , cracked or missing o-ring
  • kdidsbury Aug 16, 2010
    Not cracked and never saw an o-ring
    Brigadier General:
  • 4,088 Answers
Remove the dispenser tray from the machine and clean the exit passage if plugged with washing compounds. Use a liquid detergent if you are not already doing so. If the tray looks ok, you may have excess water pressure which might be forcing more water flow than the tray can handle. Another respondent suggested turning the supply faucets down somewhat to reduce the amount of water coming into the machine. If you have your own well, the system water pressure can be turned down at the pump control (about 35 to 40 PSI is about right). Hope this helps!
Posted on Aug 16, 2010
My Neptune MAH3 is leaking from the detergent dispenser.
The detergent dispenser is easily replaced, simply held in place by the four corner screws which fasten the door and door frame to the washing machine.
Unless the dispenser itself is cracked, your leak may actually be occurring from a loose clamp or hose attached to the dispenser. Or perhaps the leak is coming from the hoses, which are connected to the back of the machine in the same corner as the dispenser. The fill valve, to which the hoses are connected, could also be the problem. These valves are made of plastic, and can eventually crack and fail. This valve is also fairly easy to replace.
If it's been awhile since your washing machine hoses were installed, I would highly recommend changing them out if/when you repair other items. Stainless steel hoses are now available, preferable to plain rubber ones, better to handle constant water pressure. Be sure to note a date on the back of your machine with a Sharpie or paint pen the date the hoses, fill valve, or other items were changed. I do this as a reminder for the fill valve, which gets eaten up by our municipal water supply about every four years.
Aug 16, 2014 | Maytag Neptune MAH5500B Front Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Detergent stays in the dispenser
Clean and dry your dispenser prior to filling with detergent.
Use only fresh detergent.
Do not place anything ie. cookie sheets, cutting boards in the path of the water obstructing the dispenser.
Do not allow anything to fall between the racks and stop the spray arms from turning.
Always turn the hot water on at the sink prior to starting you dishwasher they use less than 2 gallonsof water in the initial cycle and they require 120 deg f water. Unless you have hot water recirculation in your home.
If you have low water volume or low water pressure due to bad impellor or windings in circulation pump. The water volume or pressure will be insuficient to reach the dispenser.
Mar 31, 2009 | Kenmore 24 in. 16492 / 16494 / 16499...
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile SmartDispense clog
I have the same problem and found the below on the GE website. It says to purge the detergent from the Smart Dispense. I am in the process of doing it now...we'll see if it works:
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Apr 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Detergent accidentally put into rinse dispenser
You need to use something to siphon the detergent out of the dispenser. I have plastic syringes for this type of purpose. You don't use the needle attachment.
If you cannot fit the syringe into the opening, then you may try to use clear plastic tubing to syphon out the detergent.
Once the flow of detergent stops, you should then use warm water to rinse the residue. If you have the syringe, you could use it to force water into the dispenser.
This may take a little time, but it is better than trying to disassemble stuff!
Good Luck
Brian
Jan 10, 2008 | Kenmore 24 in. 16463 Built-in Dishwasher
Maytag Washer, Model # MAH4000AWW (Neptune - front loader) appr. 4 yrs old
Hi john, There is a blue cover that i am suspecting you are missing from the softener/bleach dispenser. It fits over the two tubes in the dispenser and it siphons the water out. It is part number 22002266. Also the machine has a water filled balance ring. It is normal to hear sounds of water when the tub is turned. If you can see water in the spinner its a different story.
Nov 24, 2007 | Washing Machines
Re:dishwasher
Ginga, first of all it's still under warranty so I would call for service. Here's a few things to consider; first, I would switch back to the powdered detergent like Cascade. You want to make sure that the water entering the dishwasher is at least 120 to 150 degrees, anything less will cause the detergent not to dissolve. Check your loading and make sure nothing is blocking the spray arms from the soap dispenser. Make sure the spray arms do not have any cracks or splits. After the dishwasher fills, make sure that the water level is right at or just below the heating element, a short fill will cause this also. Catriver...post back.
Nov 04, 2006 | Kenmore 24 in. 16182 / 16189 Built-in...
Samsung WF328AA Front Load Washer Logo
302 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
