How do you remove the aggitator for cleaning - Washing Machines
  • oldguy5 Aug 07, 2010
    Can you provide the exact Make, Model and Kenmore model number? ..........
    Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
    The model number on top load washers is usually found by lifting the lid and looking above the tub.
    The Fixya numbers are Stock Numbers.
    Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
  • 343 Answers
No brand or model supplied.
Unable to respond.
Sorry.....Nomess
Posted on Aug 08, 2010
How can I remove the agitator to clean the liquid softner dispenser, it is clogged
you will have to remove plastic nut at top of aggitator to be able to raise the aggitator out of the tub hope this helps
Feb 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I cant lift trhe bottom aggitate plate in my hmwm8000 i have removed the cap and phillips head screw how tov lift the plate?
there should be a bolt holding aggitator on spines,if not try grabbing aggitator and pulling up while rocking aggitator back and forth it will require a great amount of force to remove aggitator fron splined shaft,also so penatrating spray may help sprayed on splined shaft.It also may need to be cleaned around splined shaft to clean built up soap build up. also a haet gun or a hair dryer on high heat on top of aggitator shaft when trying to remove may help!
Jun 12, 2011 | Washing Machines
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Washer will not aggitate all other functions work fine
Sounds like you need a set of dogs...(dog agits)...
Pop the top off the agitator and remove the bolt. Pull the agitator top off and inspect the dogs...(small tear drop shaped pieces of nylon)...
Sounds like the dogs lost their bite aka teeth.
Apr 11, 2009 | Washing Machines
Whirlpool Calypso Topload washer Won't aggitate correctly
Possibly a belt issue take the top cover off of the agitator and remove the bolt that holds it down. There will be gears inside if any of these parts are broken this will also cause it not to agitate. Let me know
Jan 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Dirt like pebbles left in the bottom of the washer after the cycle is complete
take the fabric softener cap off just pull. then look down the middle there will be a bolt 10 mm loosen it and pull the agitater
Jul 22, 2008 | Admiral AW22 Top Load Washer
GE Front Load Washer Model#GCVH6260F-Problem with no washing, spin or aggitate function but motor works fine...
try cleaning out the filter - it's behind the bottom panel (three screws to remove) you will see a round disk - unscrew it and pull out the filter. I have to clean ours every six months - it's too bad GE didn't put it in their manual, that this needs to be cleaned periodically.
Dec 11, 2007 | GE Energy Star WCVH6260F Front Load Washer
Removal of Aggitator
Remove the cap and softener dispenser by pulling it off and locate the agitator bolt. Remove bolt and lift up on the agitator
Oct 20, 2007 | Maytag Performa PAV2200
Washer repair.
Hall sensor may be damaged on the motor or the control isn't sending voltage to the motor
Sep 27, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
