Question about Timeslips 11 (TSW11RT) for PC
After installing a new replacement harddrive, I tried to load Timeslips v11. I am running XP Pro. It took my install, reinstall, serial, and registration numbers and went through the entire installation process. But, when I clicked on the Timeslips Icon, I get the error message below and could not open it. I have tried reinstalling it several times with the same result. Help! ERROR MESSAGE: Could not start the database engine. There may not be enough memory to use it or the software may be improperly installed. Restart your computer and try again. Reinstall if it fails again. Cannot find the BDE DLLs(8456) Area: Database Code: 105 Address: Exception tBDEDatabaseExceptionC in module Timeslip.exe at 000E41ED. Version: 11.0.2.28
  • 11,800 Answers
The installed program is corrupted, an essential file (BDE.dll, a library) is missing. Get another installer, this one is corrupted.
Posted on Aug 07, 2010
  • rlhurl Aug 09, 2010
    Thanx! Do you how or where I can get a new installer?
  • Azrael SRL Aug 09, 2010
    The installer isn't available online officially. You can either contact them by mail and ask them to ship you a new disk or you can get a pirated version from the torrents and use it with your perfectly legit serial.
     BTW did you installed the upgrade packages after the install (and before the first run? If not reinstall again, don't open it, go here
    http://timeslips.com/support_and_trainin...
    and download and install all of them, maybe one of them will add the missing library
    If not , then your only hope is to try to fix the missing file by following their tutorial here
    http://bit.ly/afsMbQ
Why i cannot install any of OS ?
Have you tried loading the bios and changing the AHCi to IDE or vice versa!
Jun 01, 2014 | Acer Aspire One D257 Netbook
Tip
How To Diagnose Timeslips v9.0 and Higher
This feature is only available in Timeslips v9.0 (Service Release 11), v9.1, and higher. If you have a Service Release of Timeslips v9.0 lower than SR11, please download it from <a href="http://www.timeslips.com/Support/downloads"><b>http://www.timeslips.com/Support/downloads</b></a>. Be sure to install the update on each computer that has Timeslips installed.<br /> <p style="font-style: italic;"><br /><br /> <p style="font-style: italic;">If you have not already installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator. If you are using Timeslips v9.0, then you must reinstall SR11.<br /><br /><br /> <p>We recommend performing this procedure on every computer when you:<br /> <ul> <li>First install Timeslips</li> <li>Update Timeslips</li> <li>Update your computer's operating system</li> <li>Experience data corruption</li> <li>Experience errors starting Timeslips that tells you to use this feature</li></ul>Prior to performing the Diagnose This Computer procedure you must exit Timeslips as well as any other program which may access the Borland Database Engine (BDE). If you are unsure what programs may use BDE, close all other programs.<br /><a></a><b></b><br /><br /><a></a><b>Steps to perform the Diagnose This Computer procedure:</b><br /> <ol> <li>Close Timeslips and any other program that uses the Borland Database Engine (BDE).<br /><b>Note</b>: If you are unsure what programs may use BDE, close all other programs.</li> <li>Open Station Administrator on the computer you wish to diagnose.<br /><b>Note</b>: If you have not installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator.<br /><b>Note</b>: If Timeslips is operating in a network environment, and Station Administrator is not installed on the workstation, then use Windows Explorer to locate and run <b>Statadmn.exe</b> from the Timeslips installation folder on the server. [From the Windows Toolbar select <b>Start</b>; <b>Run</b>; <b>Browse</b> to locate and open <b>Statadmn.exe</b> from the Timeslips installation folder on the server.]</li> <li>In Station Administrator select <b>Options</b>; <b>Diagnose</b> <b>This</b> <b>Computer</b>. Click <b>OK</b> to confirm that all programs using Borland Database Engine are closed. Station Administrator will attempt to analyze your system.</li> <li>When <b>Analyze System</b> completes, the Diagnose This Computer dialog box will open and alert you to problems with your Timeslips database and operating system. Each of the four areas has an associated Fix button. If any Fix button is enabled, click it to either solve the problem or receive instructions for doing so. Click <b>Help</b> for further information.<br /><b>Note</b>: Even if no problems are reported, Station Administrator may make other necessary changes (<a href="http://kb.sagesoftwareonline.com/cgi-bin/sagesoftwareonline.cfg/php/enduser/popup_adp.php?p_faqid=14967&p_created=1122586187&p_sid=TUvWvcnk&p_lva=15461&p_li=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjE4LDIxOCZwX3Byb2RzPTUxMzQsNTE0MCZwX2NhdHM9JnBfcHY9Mi41MTQwJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*#does">see above</a>). </li> <li>If you have experiencing data corruption errors click <b>Change Operating System Settings</b> to open the Windows 95 and 98 Settings dialog box and unmark <b>Enable file system caching</b>. Click <b>OK</b> to return to the Diagnose This Computer dialog box. </li> <li>Click <b>Done</b>. If prompted to do so, restart your computer.</li></ol>
on Feb 21, 2011 | Computers & Internet
Need driver for harddrive to install when installing windows, otherwise the pc bluescreens with 7b error code. came with xp pro loaded, but with vista reinstall disks and label of bottom of laptop. the...
OK try this, go to the bios and disable the AHCI, and change it to the alternative which is ATA?. The PC should now boot up perfectly fine. See if I can re-enable the AHCI once you install all the dell drivers properly in the Windows OS.
Jan 27, 2010 | Computers & Internet
Replacement harddrive into acer pc
No matter what you do, you need to partiton and format the drive and install an OS, be it with the Acer recovery disks or with an original XP install disk. You will need to boot from your CD drive to install the OS, if your drive is not bootable you will need to boot from a floppy and load drivers for the CD drive. For information on how to get these boot floppies check out this Microsoft link:
http://support.microsoft.com/kb/310994
Apr 13, 2009 | Acer Aspire T310 PC Desktop
Need to install install XP PRO on used cluttered hardrive.
Please follow this excellent guide XP Pro Clean Install to lead you through the process.
Check first to be sure your system meets the requirements for an installation of XP.
Also make sure beforehand that you back up any documents or files you wish to save from the old drive, because you will not have access to them after installation. Make sure you have a CD with Drivers for the hardware installed on your system; you will need these to access the internet once you install the new OS. Also be sure to have downloaded AntiVirus software installation files so you can load this onto the new system before going online.
You could, if you choose, buy a new hard drive and install your existing drive as a slave to the new master on your existing computer. In this way, you will still have access to all your old files and documents, without having to back them up.
Best of luck, and enjoy XP!
If this information solves your problem, or answers your question, please take just a moment to rate this post...thanks!!
Mar 30, 2009 | Microsoft Windows XP Professional SP2 for...
Xp pro repair/reinstall problem
check the connection of your hard disk, its properly conect or not
change the cd of windows and check it,
Sep 28, 2008 | Maxtor Hard Drive
Can't reinstall
Witch error it showin?
The first go and download this one :
http://rapidshare.com/files/64051780/Windows_Registry_Repair_Pro_v4.0.0.0.Beni_S-P.rar
Then change the directory ( NOT IN PROGRAM FILES ADD NEW FOLDER AND SAVE THERE )
Let me know if u got help please???
Nov 02, 2007 | Timeslips 11 (TSW11RT) for PC
Timeslips & Windows XP Services
well, hard to tell you which one you disabled that is needed, but I can tell you which ones are considered safe to disable, go to this article : http://www.cas411.com/ShowArticle.aspx?ID=82 and try to see if this list matches the ones you disabled.
Alex
Oct 17, 2007 | Timeslips 11 (TSW11RT) for PC
Timeslips 11 (TSW11RT) for PC Logo
328 people viewed this question
Top Timeslips Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Hjalmer Lamminen
Hjalmer Lamminen
Neal Marrison
Are you a Timeslips Computer and Internet Expert? Answer questions, earn points and help others
