Question about Car Audio & Video
What type of gas does a 95 eclipse gsx use? thanx!
    Problem Solver:
  • 20 Answers
Use the cheap stuff, you won't notice much improvement from the higher priced fuels. I have a big V8 and use the 87 octane, it works just fine. As for expensice fuel additives. You can buy that at your local auto parts store and save your self a few bucks at the pump. There are many choices for the additives, but use an injector cleaner in the fuel every few months will get you better protection in the long run and be less expensive.
Posted on Aug 07, 2010
Dash lights and tail lights stopped working on my 95 eclipse gsx. We have checked all fuses and still have come up with nothing
How did you check fuses? Volt ohm meter? or visual. If visual, sometimes they look good, but actually are not. Otherwise, what preceded this symptom prior to or immediately prior to? I would try to connect this with the behavior before.
Apr 02, 2015 | 1995 Mitsubishi Eclipse
How to change the power steering to water pump belt and the water pump to alternator to something else belt
well you used the tensioner to loosen and remove the outer one first then the inner one and reverse procedure to put on new belts
Mar 19, 2015 | Cars & Trucks
Firing order chrysler 420a.In Mitsubishi Eclipse 2.0
1999 Mitsubishi Eclipse GS 2.0 liter DOHC L4
1999 Mitsubishi Eclipse GSX (AWD) 2.0 liter DOHC Turbo L4
Hope helps (remember rated this).
Jun 24, 2010 | 1999 Mitsubishi Eclipse
95 Eclipse speedometer does not work.
if it has an electrical speed sensor type system, chances are the wiring from the sensor to the computer are NFG. get the system checked you might have a rotted out wire
Feb 25, 2010 | 1995 Mitsubishi Eclipse
Change the engine computer
before i start to explain how to replace this i cant stress this enough MAKE SURE THAT IS THE RIGHT COMPUTER FOR THAT ECLIPSE. the 95 non turbo eclipse has a different computer from the 96 to 99. and the gst and the gsx computers are different from eachother. the gst and the gsx computers are also different from the 95 and the 96-99 non turbo eclipses. when you get the computer i would bring your vin number to any local parts store or the dealer and they should know what to do with it. now that that is said. which computer do you need replaced. if your talking about the one inside the car it is located under the center console right behind the e-brake. removing that can be a challenge due to the several bolts that holds it on. you can use a phillips head screw driver but i wouldnt recommend it. i believe it is a 10mm socket that they will fix. after you get that off i would disconnect your battery. wait a few minutes than ground yourself out to the bracket holding the shift bar on(just grab ahold of it) after that is said and done there should be 4 bolts holding it on. (i believe 10mm cant remember) and a clip with several wires going to it. before installing. clean up the area around where the computer sat. remove any dirt or anything that may be there. check the clip that plugs into it for any damage, broken or burn wires, or if the plastic clip in itself is damaged. if not the dealer would be the only place to replace this at and i would strongly recommend a garage putting it in. if all is good installation is the opposite of removal. after you get everything together turn the car to the on possition with out starting the motor and let it sit for about 10 min. this will allow that computer to learn the way your car is set up. after that you should be able to start the motor with out a problem.
if you want the computer under the hood than its simple disconnect 1 or 2 clips and 3 to 4 bolts holding it on. inspect everything before installing the new computer along with cleaning up and dirt or rust in the area. and do the same process i explained about the other computer
Oct 05, 2009 | 1998 Mitsubishi Eclipse
1995 mitsubishi eclipse gsx. Getting only 190 miles on a full tank of gas, driving slowly. Check engine light comes on. Only mods: aftermarket air fliter and blow of valve. Please help!
Check the code at advance auto parts, replace the PCV valve just in case. It is an inexpensive part, and if it is clogged will cause the engine to consume more fuel than normal. Also, check the EGR tube coming out of the EGR valve and going to the Intake Manifold. This clogs up with carbon, and is a very common problem that throws a code.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Sep 26, 2009 | 1991 Mitsubishi Eclipse
My gsx won't start
Check the fuel system2_bing.gif to make sure it's getting gas. Take the back seat out and turn the ignition on without cranking the car. You should hear the fuel pump make noise for a few seconds as it pressurizes the system and then turns off. If you don't hear anything, it would probably be the pump or one of the two relays on the firewall2_bing.gif next to the master cylinder. I replace the cheaper of the two relays and that fixed my problem.
Jun 05, 2009 | 1995 Mitsubishi Eclipse
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
