Icy connection to house and inside unit - Heating & Cooling
    Problem Solver:
  • 10 Answers
In the cooling cycle, a low "freon" charge or low air flow can cause the line set to ice up. Check your air filter to be sure that low air flow is not just a dirty filter; then call for a system check up. (you do need your vents open throughout the home)
Posted on May 03, 2008
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
The outside unit fan kicks on but the inside unit does not.
It sounds like your blower motor has gone out., the buzzing would be the motor trying to start but maybe locked up. You most likely have a completely burned out motor so you no longer have any buzzing. The motor can be changed out by a do it yourself-er with some mechanical and electrical know how. If you do it yourself be sure to replace the motor run capacitor.
Sep 02, 2012 | Goodman CKL36AR36 Air Conditioner
SAMSUNG FRIDGE FREEZER NOT COOLING. ICE BUILDING UP ON REAR PANEL, MODEL RS20CCMS,
Fan unit or defrost element has failed, usually the defrost element, not a hard DIY, just be very careful. Check fan is running first and that it is not part of the new icy growth inside the freezer, regardless, you will need to defrost this glacier first before you can do anything and PLEASE dont resort to a blow torch, there is plastic and pressure gas in there. Just be patient and watch the fins on the cooling unit, you could shave with that stuff. Good luck, any probs, call me on 08 9523 0552. Russ
Feb 27, 2011 | Samsung Freezers
How do you install a thermo scientific multiskan ex reader
1. Buy The Unit from Thermo, Thermo Distributor or @ Indonesia you can buy from Elokarsa, PT
2. Unpack the good
3. Unpack the unit from the plastic/aluminium warp
4. Unpack the other part from each plastic pocket
5. Check all items by referencing of items check list letter
A. Open the units by unscrew the bold on left and right side using L key (including in item list with 2 fuses)
B. Open the filter wheel and place inside the reel housing
C. Put halogen lamp inside the housing and connect power cable (do not touch the internal lamp directly by hand / finger)
D. Close the unit by screwing these bold
E. Plug power cable, in unit (rear right unit, side of power switch)
F. Power on the unit, leave 15 second for the initialing and autocalibrating
G. The mini dot matrix screen should be showing the unit software version and word "Ready"
H. Push the param button on board, set the periperal by your self, like the manual
I. If the unit does not have a trouble, you ready to connect the unit using data cable (include inside the box) and direct connect to PC using RS-232 rear of PC or you must using USB-RS232 adapter for help an connection, install the Ascent Software on PC using Ascent Software CD including the box, choose "multiskan" and follow the instruction.
J. Finish, you can learn by doing, guiding with manual book (white one)
Good Luck
ST - Elokarsa Techinical Support
Nov 19, 2010 | Health & Beauty
Hi, After finding out that Freon is low by seeing snow/icy surface on outside compressor, I went up in the attic to find snowy/Icy surface all over the coil inside the air handler. I wahsed it and made...
Hello
Your still froze up.There is a freeze cutoff device in the air handler upstairs.
Look for a thin silver color tube near the coil and follow it to the control box,there may be a reset button.If not, try using a hair dryer to warm up the coil and it should reset itsself.
These freeze devices can take an hour to reset on there own sometimes,do not run the compressor while doing this.
Aug 30, 2010 | Ruud Heating & Cooling
My freezer on a PSS27SHMD will not get cold enough. I'd like to try to fix myself,but I need help troubleshooting. I took the back off. It apprear that the condenser fan is running, The Condenser was a...
clean the coils next to the compressor with a brush and vacume... they can be reach from the front or the back but turn the unit off first :)
Jan 02, 2010 | GE Refrigerators
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Thermostat install for 1989 Maxima
it goes inside of the housing unit. but when you put the housing unit on, the stem should be pointing to the engine
Dec 02, 2008 | 1989 Nissan Maxima
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
