My tv is all blackexcept a wihite line through it and no sound
  • 8,617 Answers
If the line is going across the TV the vertical deflection circuit needs repair. If its going from top to bottom the horizontal circuits are needing repair. Please post your model number and I will be better equiped to let you know which part is likely at fault.
Posted on Apr 27, 2008
Purple and blue screen on dlp tv
Sounds like a problem with the Vertical Video Card.
Have fun finding one. If your TV is still under warranty... send your TV off for repair.
Oct 03, 2012 | Samsung HL-R5656W 56" DLP HDTV
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
Dec 09, 2009 | Sony KP-51WS510 51" Rear Projection...
Colored lines across TV
what this sounds like is that you may have a cable in the wrong part of the tv like maybe a vcr or audio cable check your inputs in the back of your tv that sounds like it what it might be i have a big screen tv and if i have a cable in the wrong part it will hiss and have lines on it too i hope this can help if not reply to me at Jonk3y @aol.com
Sep 23, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
BLACK LINES ACROSS THE SCREEN Panasonic PT-47WX51E
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
How do i get the sound from my Philips TV into my samsung 2.1 home cinema system?
To get sound from any TV (including Philips) to an amplifier or a home cinema system, the TV should have a LINE OUT RCA pair. Thereafter, it is a simple case of connecting said Line OUt to one of the INPUTs of the cinema system.
Often (but not all), Cinema Systems have their own TV tuner and would provide a video out that could be connected to the Video IN of the TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Samsung Televison & Video
Sony /tv /no picture but sound
There is a fault on the line output stage either dry solder joints on then transformer or relating components or the line output transformer or transistor is faulty and needs replacing. Hope this helps.
Jul 17, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
No picture but sound on panasonic plasma
Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues.
Mar 07, 2008 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Horizontal grey lines on TV
Sound like you have to turn down the G2 (screen)controls. They are turned up too high.
Jan 01, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
