Question about Singer Sewing Machines
I have a singer touch tronic 2000 when i run the needle down it hits something metal below the bobbin and wont go all the way down
SOURCE: singer 5817c
Hi, actually I can help with your problem but maybe you can help me with mine. A friend gave me the same model...without the instructions. Would you be willing to give me a pdf scan or photocopy of the manual, please? Let me know at arielle.bkshlf@gmail.com. Thanks!
Posted on Jul 19, 2008
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 136 Answers
SOURCE: same problem on a singer 4166
yes
Posted on Aug 29, 2009
  • 20 Answers
SOURCE: needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Posted on Oct 13, 2009
SOURCE: Needle Hitting Solid Metal
On my machine, that usually happens when the needle gets bent. Try replacing the needle.
Posted on Oct 31, 2009
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
The needle will not go up and down on my singer touch tronic 2000
How long since the last thorough clean and oil? Bet the old oil has dried and is preventing things from moving. Refrain from running the motor until the problem is resolved--further use could burn up the motor.
Mar 11, 2017 | Singer Sewing Machines
Noisy Singer Touch Tronic 2010 sewing machine
the noise could be from the needle /hook timing, or bobbin carrier
take it to a service center for a service and to find out the worn/ loose parts
Dec 21, 2015 | Singer Sewing Machines
I was recently given my mother-in- law's Singer touch-tronic 2000 sewing machine. The needle bar does not work. What could the problem be. Please help me. Thank you
check with a singer service centre but some singers have a belt drive inside the case that works the needle bar mechanism
they are known to break
it is in side at the right hand end just behind the outside pulley
Jul 25, 2015 | Singer Sewing Machines
Bobbin will not load on a singer touch-Tronic 2000
Please check the bobbin tension or you bought a new bobbin and case otherwise check the timings.
Jan 31, 2014 | Singer Sewing Machines
Ishow me how to rewind the bobbin on a touch tronic 2001 singer sewing machine
Presser foot up, takeup lever at the top, thread the machine normally all the way and through the needle, open the needle plate, press the little lever to the right, wind the thread from the needle round the presser foot screw, press on the foot control slowly and wind the bobbin, when you have enough thread on the bobbin close the slide plate the winder will drop down, pull the threads to the back of the machine and start sewing
Oct 30, 2013 | Sewing Machines
Singer model 640 needle hits metal in bobbin area on downstroke
Yep, it's out of time. Take it in for service. Ask for cleaning, lubing and re-timing. Otherwise they will just time it and if it is dirty and dry... it may just fall out of time again.
Also remember you can never turn the hand wheel backwards to the way it is intended to go... that causes this issue in some machines.
Aug 25, 2012 | Singer Sewing Machines
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Nov 08, 2008 | Euro-Pro 9120 Computerized Sewing Machine
Sewing Machines Logo
70 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
