Question about Kwikset 909 909-15 Satin Nickel Smart Code SmartCode Signature Series Touch
I just installed a Kwikset lock but when I put the code in to unlock it, it unlockes but the keypad turns red for 3 seconds.
  • Anonymous Mar 19, 2014
    Put in my own code the lock will unlock but won't lock from the keypad
I hope this helps someone. i just spent three hours trying to fix this problem. this occurance happens when the internal assembly is screwed down too tight to the door - somehow it doesnt give it enough give to turn the lock 100%. just loosen up the screws from the assembly to the door, and everything should now function correctly.
Posted on Sep 12, 2010
  • Mark Shust Sep 14, 2010
    Actually, that wasn't the issue. The issue was the metal latch had wiggle room, and the door never latched tight enough. I moved the screw location to a tighter location, and now it works every time.
Just installed keyless entry lock. Lock button works fine, enter code and deadbolt only partially retracts. Worked fine the first time, will not completely unlock since. Key works to fully unlock. Tried...
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Oct 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Just want to change 4 digit code to new one
Do this, with the door open:
Remove cover from assembly by sliding cover up and off. You will then see the program button.
A programmed code can be from four (4) to eight (8) digits long.
Up to 2 user codes can be entered.
Excess delay in the programming steps once started will cause unit to beep twice and will require you to restart from step (a).
Programming the first User Code:
a. Press the program button on the interior unit once.
b. Enter in 4 to 8 digit code onto the keypad.
c. Press the "LOCK" button to save code.
d. Extend the bolt by pressing the "LOCK" button and re-enter the code to test. The bolt should retract to the unlocked position. If it does not unlock, repeat steps (a) through (c).
Programming the second User Code:
a. Press the program button on the interior unit twice.
After programming in just one new code, the existing old code may still work. I suggest that if this is the case, that you program in two codes to make sure that the old one is over-written. You may try programming in the same new code both times if you don't want to have two codes.
Here is a link to the installation and programming instructions that I excerpted the reprogramming instructions from:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For further assistance or warranty information: call 1-800-677-5625 USA & CANADA
or visit, www.kwikset.com
Jul 26, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Just installed kwikset 909 all worked fine except that I cannot turn the cylinder manually with a key to unlock or lock. it locks and unlocks with the keypad.
For your review, here is a link to the installation instructions for your lock:
Under the Troubleshooting steps at the bottom, you will see this text:
Q: I just completed the installation of a Smart Code unit on my door; I am unable to operate it manually, although I checked for smooth bolt operation during installation. What should I do?
A: You need to run the "Bolt Direction" routine again; allow the process to run to completion see Section 8 in User's Manual.
So please go through the installation instruction's Section 8 again. (Remove the battery pack first.) It is important to follow this procedure very carefully for success!
If you feel that you are following all steps correctly but the lock is still not functioning properly, please contact the Kwikset Customer Support:
Call: 1-800-327-LOCK (5625)
Jul 20, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset keypad deadbolt will not lock or unlock. Batteries OK.
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
Apr 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Do you know how to reprogram digital code?? kwikset 907 lock
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Jan 06, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Lock won't work. Our unit became sluggish. We changed the batteries, but now it won't lock or unlock using the keypad. Help.
Kwikset has a lifetime mechanical and finish warranty. Contact them from here:
Dec 18, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
# WED1460 X3 VT 4LS2 I changed the batteries, now I get a flashing green light when the lock is closed or unlocked. It does not turn red at all. Every thing works when keypad is used.
The Weiser and Kwikset locks are identical, so these instructions will work for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Nov 17, 2010 | Weiser Lock Powerbolt 1000 Lock
I installed this last night and it was working fine. Tested it several times, showed the family, etc...Everything worked great. My son left for 10 minutes and came home and it no longer worked. The keypad...
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
You can contact them from there for further assistance.
Oct 11, 2010 | Kwikset 907 907-15 Satin Nickel Smart...
Won't unlock door and beeps when code is entered
Got in contact with kwikset took out battery pack then put it back in. keypad reset itself.
Dec 28, 2008 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
Kwikset 909  909-15 Satin Nickel Smart Code SmartCode Signature Series Touch Logo
1,160 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
