Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Think i have a problem with governor on my 21hp v-twin briggs. it jumped to max speed and can't get it to slow down. which part of the governoring system could have let go?
  • 3 Answers
Check for a broken spring on the governor linkage, follow your throttle control cable down to where it attaches to the throttle mechanism. In behind where the cable attaches you should be able to see a spring on the governor arm, the spring may have broken or somehow came out of its attaching point. Obviously be very careful about over-revving the engine, it could result in a broken connecting rod and a hole in the side of your crankcase.
Posted on Aug 10, 2010
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Sep 23, 2008 | Garden
Governor does not seem to work
Sometimes the governor gear inside the engine breaks and you have to replace it. Did you try to adjust the governor by putting the throttle full and unloosen the screw on the governor arm and push the governor piece the same direction as the throttle opens and tighten the screw.
Mar 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
The govenor rod cannot be adjusted. The springs are intact. Motor revs up but will not idle down. It is 23 HP.
Just guessing here, but if there is no control of the throttle and the engine over revs, then more than likely the governor control is broke. Briggs if famous for that problem. Governor is around 25 dollars and a lower crankcase gasket. Requires the engine to be pulled, lower crankcase removed, remove all pieces of old governor and then re assemble with new governor and gasket.////Before doing all this check that both springs are on the governor on the exterior of motor. If you manually hold the governor arm back, counterclockwise, and it still revs, then you need to replace governor. Don't let it rev for long or it with throw a pushrod or worse. good luck
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 24HP V-Twin Briggs that i blew up. I found the parts i needed and rebuilt the beast. It starts and runs but i cant get it to throttle down. I split the case again and inspected the governor....
A big vavume leak and or the throttle blade doesn't close or it gone ( missing). the carb should close all the way ( you can't look thiugh it) with the linkage off you should be able to run it by hand with good results. if you can find out the correct way to put the springs on and just move things around or gat a look at one thats working right and you may see whats put together wrong on yours.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Apr 18, 2009 | Briggs & Stratton Garden
Porter Cable 5500w generator (10hp BS) will not regulate speed.
While attending college I worked at a tool rental center and learned a great deal about matching generators to customer requirements and troubleshooting customer owned units. There are simple tests that you can perform, however, first some info on what to expect from a generator. Most generators are overrated and under powered. You should only expect to get about 60 - 75% of rating. Example, a commercial honda 5000w generator has an 11hp motor that can only produce about 9.5 hp at 3600 rpm. If a customer needed 5000w of power, we would rent them an 8000w generator because as the generator is loaded to max the voltage will drop. You generator will probably only provide steady voltage ex. 115v at 60 cycles to about 3500w then voltage will begin to drop. New generators have automatic voltage regulator that varies the power to the armature increasing/decreasing the power of the magnet. These voltage regulators suffer a high failure rate and are expensive. If your generator is not giving you 3500 watt at 115v 60 cycles your engine may have a few problems and your power generator end may need tweaking. (I would not expect to achieve 5500w at 115v with briggs 10hp) .
The governor is about 2 inches in diameter and turns off the cam gear inside the engine. It is flyball type with two or three small arms that react to rpm. The faster the engine turns, more force is applied to the governor arm to reduce engine speed. Easy to test, with engine running use finger pressure against the arm to increase speed and you should feel a greater resistance as the engine speed increases. Another simple test, remove air filter to expose butterfly inside the carb. Move the governor arm and check that the butterfly opens fully. If it does not open fully linkage and governor is not set correctly. Next, start engine and load generator up to max and check that butterfly opens to full as the load increases. When the butterfly opens all the way under load the engine is at max. Add up the wattage of all the tools/appliances you used to load the engine to get an idea of max load . Lets assume that the shop adjusted the governor properly, if the governor was not working the engine would over rev. and damage would occur. As you were told the governor spring controls speed and can be adjusted somewhat by bending tab or adjustment screw. But a review of your generator manual or that series of briggs engine will show that there are several governor springs available and different placement holes on the governor arm to attach the spring that will change the power curve. Pulling on the spring can only do so much, however changing the spring to different gauge /turns/material or differnet location on the governor arm will cause the engine to perform differently. These springs are sold thru briggs dealers by part number for your engine. This would be considered tweaking to get a different power curve.
Now for the generator. Some generators have a capacitor incorporated in the windings. This capacitor must measure within 95% of rating. Remove from circuit for testing. Finally look very carefully at the commutator rings for any evidence of brush bounce. If the brushes do not perfectly seat you will lose power. If your generator is brushless you can only hope that the diodes are within spec. because it is too difficult to test them. They also must be removed to test. Finally if your generator has an automatic voltage regulator the only test would be to replace with a known good part. At the rental center we stocked spare parts so that we could quickly find fault. There is soo much to learn and the life too short. I hope this helps good luck, please email your questions.
Dec 24, 2008 | Coleman Powermate Premium Plus 6250W...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,711 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
