Question about Garden
Check for blue, snappy spark (gapped 0.020") at the spark plug. Check the fuel filter, air filter and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the fuel mix is correct and fresh. Make sure the primer bulb (if equipped) pulls in fuel after several pumps. Check the carburetor fasteners for tightness. Make sure the engine case is free of sawdust to prevent overheating. Check the chain oiling--it should throw off a thin line of oil onto some cardboard from the bar tip with the engine running fast for several moments. The engine should 4-stroke at speed while unloaded, but immediately 2-stroke when cutting. Adjust the H jet needle to achieve this. Set the L jet needle so that the engine 'follows the throttle' and idles fairly well. Hope some of this helps!
Posted on Aug 07, 2010
Sep 02, 2014 | 1993 Nissan 240SX
Jul 24, 2014 | 2001 Ford Focus
Mar 10, 2014 | Cars & Trucks
Jan 09, 2014 | Suzuki Cars & Trucks
Its
a hot start issue.
Can
be related to low fuel pressure or problem with crank sensor.
Also
it can be weak battery or starter.
But
possibilities are to be inspected to confirm what exactly it is.------
To
troubleshoot and confirm the issue,i suggest you refer few solved help links
with similar types of problem like yours:------
Click
the link below:------
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These
details will help.
Thanks.
Dec 04, 2012 | 1991 Oldsmobile Cutlass Calais
Its
a hot start issue.
Can
Also
But
To
Click
These
details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Jul 31, 2012 | 1996 Jeep Grand Cherokee
Oct 12, 2010 | Garden
Aug 17, 2010 | 1993 kawasaki VN 750 Vulcan
Apr 01, 2010 | 2008 Husqvarna SM 450 R
62 people viewed this question
