Question about Craftsman 4 Cycle Blower/Vac
32cc 2 cycle craftsman blower replacing fuel lines think i got them hooked up wrong can you tell me the right config? small and large out of tank primer bulb in and out 2 lines to right side of carb
  • 4 more comments
  • rbratton375 Aug 07, 2010
    lines out of tank go where
    small line from tank goes?
    large line with filter pu in tank goes?
    does primer push fuel into carb pull it
    does the primer push gas into carb and is this from the same line that feeds the carb once its running
    does the primer push gas into the carb and is that from the same line that feeds carb once its running
    does primer push fuel into carb and is this from the same line that feeds carb once its running
  • 11,896 Answers
The line on left side is for the purge. The one on the right is straight to carb.
Posted on Aug 07, 2010
  • 11 more comments
    small and large line out of tank go where
  • Nate Stansfield
    Nate Stansfield Aug 07, 2010
    Line on left goes from tank to purge to carb, the one on right goes straight to carb, that is a return line as well.
    Do you have a model # so I can double-check the diagram? I was just looking at my blower and that's how mine is.
  • Nate Stansfield
    Go to this Addy http://www3.sears.com/ and Select the Lawn Equipment Box. Then Enter the Model Numbers. Then Verify the Equipment and Click
    Continue. Then Select the Carburetor Diagram.
    1. ok small on left from tank goes to purge sucking in and then the purge out goes to carb
    2. large on right w/filter goes to carb
    carb has 2 inlets
    one shoots gas into top of bowl that would be the from the purge
    is this correct
  • Nate Stansfield
    Also here:
    www.reinsmith.net/.../craftsman/Craftsman_32cc_Leaf_Blower-Model_358.797922.pdf
  • Nate Stansfield
    You have one large fuel line and one smaller. This eliminates some
    chance for error. If you have 2 small fuel lines to the carburetor
    connect them and start the engine. Reversing the fuel lines will not
    prevent the engine from starting. If you have them connected backwards,
    the engine will start and die. Reverse them and you will be correct.The
    routing of the fuel lines vary from model to model. Keep in mind that
    the primer bulb circulates fuel from the tank, through the carburetor,
    and back into the fuel tank. One line goes from the fuel tank to the
    carburetor. One line goes from the fuel tank to the primer bulb, from
    the primer bulb to the carburetor, and back to the fuel tank.
    I am sending you an image showing the fuel line connections for Craftsman blowers.
    530-054695
    does purge push or pull fuel through carb
    530-054695
    530-054695
    unable to access that site on either one of my computers???
    model# 530-054695
    does primer push fuel into carb or pull it
  • Nate Stansfield
    A purge pushes to carb. Pulls from tank, pushes to carb
  • Nate Stansfield
    the line withought purge just sits on the inside of the tank. it doesen't connect to anything. Just shove it in there and your good to go.
    For the connecting, make sure that the line with the filter on the end
    (in the tank) goes to the imput. Push the line onto the carb. to make
    sure you got the right one, pump the bulb and make sure fuel spits out
    the other hole on the carb. Then attach the other line to that spot. As i
    said above, just put the output line inside the tank.
  • Nate Stansfield
    the primer line builds up pressure in the carb. Once it has pressure it continues to pull the fuel through the same line. One line (this line) feeds fuel to the carb. The other line is just a return line to the tank. It actually can be removed completely and won't affect anything.
  • 2,926 Answers
The primer pushes fuel into the carb, but IS NOT the same line that feeds the fuel. If you give a model number, I would be able to help further,and I may have a diagram.
Posted on Aug 08, 2010
    President:
  • 2,030 Answers
There should only be two lines, simply reverse them.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
  • Sean Wright
    Sean Wright Aug 07, 2010
    larger line goes from tank to larged diameter tube, smaller hose is for primer bulb
  • Sean Wright
    Yes it does you are correct
Fuel line routing on craftsman blower vac serial number 9528n06419
The small line goes to the fuel filter and the larger one is the vent to the fuel tank. The primer should have a large and small outlet and then you can put the small to small and the large to the large outlet. The fuel line from the tank goes to the carb. Hope this helps.
Apr 29, 2015 | Craftsman Garden
How do I find diagram for fuel lines ?
You should have 2 lines, one supply, and 1 return. If you have a pump primer, it does NOT pump fuel into the carb. It DRAWS fuel thru the carb back into the tank, so its easy to tell which line is which, and also the supply line will have a filter on it.
Oct 08, 2014 | Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 18, 2012 | Garden
My 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Nov 15, 2011 | Garden
Someone just gave me a Craftsman 32cc blower without the manual. What fuel does this use?
IF it says 4 CYCLE then it uses regular gas.(87-89 octane unleaded) Another sign to prove it's 4 cycle it should have a crankcase you keep filled with oil.
Jul 18, 2010 | Craftsman 4 Cycle Blower/Vac
Need to know the fuel line routing including the primer bulb.
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Look carefully at the 2 nipples on the carb. You can tell one is slightly larger than the other. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. completing the purge circuit. This info pertains to the Craftsman 32cc with Zama carb and may work on the 25cc model as well.
Jun 01, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
32 cc blower not starting
your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
Jun 29, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
2,604 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
