Question about Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl
The blades on my Sinkmaster 550 garbage disposer needs replacing. How do I take it apart and replace the blades?
    Scholar:
  • 122 Answers
That is a project I wouldn't reccomend. besides the "blades" are not really changable. The blades are a piece of metal cut at an angle and when they spin they grind the food by rubbing against a series of holes in the base.
if the disposal is not grinding the food, then its time to replace the disposal.
Posted on Aug 17, 2010
Titan garbage disposal
Push reset button located bottom of disposal? Use broom stick and rotate stuck cutter disk?
Copy following link to troubleshoot by type of problem:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Titan appears to be repackaged sinkmaster garbage disposal.
There is no service manual or installation manual on brief web search. However link above has manuals sinkmaster and other brands .
Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 09, 2013 | Garbage Disposals
Sink master 850 disposal parts
Copy following link for disposal parts:
Repair clinic appears to carry the parts ... assuming your sink master is same as sinkmaster
http://www.repairclinic.com/Sinkmaster-Garbage-Disposer-Parts
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#parts
http://waterheatertimer.org/pdf/Sinkmaster-sell-sheet.pdf
There is no clear parts sheet that shows Sinkmaster/GE disposal parts numbers. The product does not have installation manual posted online.
Call Sinkmaster 800-854-3229 to check on parts and ask about 10 year warranty.
May 25, 2013 | Electrical Supplies
I have a 950 Sinkmaster garbage disposal. It will not run. If I turn the grinder about a 1/4 turn with a long handled tool, then turn it on, it will run. After turning it off, I need to go through the...
The motor start winding has gone bad.
Or voltage to unit has dropped to less than 80% rating plate. 115 Volts x 80% = 92 volts.
Replace disposal using steps shown following link:
Nov 23, 2012 | Electrical Supplies
Where can I get a replacement for splash guard
Splash guards are sold by brand name, but many brands simply repackage more famillar brands such as sinkmaster or insinkerator:
Add a comment as needed
Mar 08, 2010 | Maytag DFC5500AAX 3/4 HP Continuous Feed...
Leaking sinkmaster 850 garbage disposal
I have had these apart. The leak is from a seal around the motor shaft. By the time it is leaking the shaft has pitted to the point a new seal will not repair it. Getting it apart can result in damaged parts as it is sealed together with very tight tolerances and a glue like sealer.
Eric
Jul 02, 2009 | Food Processors
Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
853 people viewed this question
Top Buck Home Experts
Gene Haynes
handygirl911
handygirl911
salaberrios
salaberrios
Level 1 Expert
Are you a Buck Home Expert? Answer questions, earn points and help others
