Question about Sony Bcg 34HRMF4 Super Quick Charger with Lcd Indicator And 4 Aa Batteries
Need fault codes for QuiQ battery charger model 912-3600
Battery won't charge
If the battery wont charge the item will need a service engineer to test it. I am not sure of the particular model but there is a possibility that either the charger itself is at fault OR the charging circuit has either a diode or capacitor damaged.
If the charger plugs into a 240v socket in the house have the charger checked to show voltage is being output by it.
If it is then how old is the battery on the scooter? does it need replacing? have a voltage test done.
If both the battery and wall charger if there is one is OK then I would say another part of the vehicles circuitry made be at fault and suggest you have it looked at. .
Apr 24, 2016 | Pride Celebrity X 3-Wheel Electric Scooter...
Kipor kde 6700ta GENERATOR
There is, on most generators, a fuse of approximately 8Amps in series with the charge system for the battery.
If the generator produces AC and there is no charge to the internal battery, I would suspect the altenator winding, diode pack or regulator.
Nov 14, 2013 | Computers & Internet
FAULT CODE SAYS BATTS ARE LOW AFTER CHARGING
hi, lets work on the assumption that your scooter is correct in saying the batteries are low, why is that ? , well you need to look at the charger and if possible try another charger , the other thing that could have happened is the charger fuse has blown, this is located on the tiller stem
If you are convinced that the charger and fuse are okay , look at the batteries, just because it a new scooter does not mean it new batteries ., let me explain let say your scooter has been assembled a year ago, batteries fitted , now the batteries have not been touched during that period , that in itself can kill batteries or as soon as you start charging them they give up.
I have seen this happen on many occasions.
Please rate my assistance
Regards
Jan 03, 2013 | Pride Pursuit XL PMV
What does a fault signify?
I hate this about automatic electronic battery chargers; they shut down when the battery isn't perfect. The battery may have an internal short or the specific density of the electrolyte may be high or low. The plates may be sulfated as well. An old-fashioned non-electronic charger would have charged it anyway.
Apr 02, 2017 | Vector Black And Decker High Frequency...
InvaMed Sovereign Mobility Scooter Model S888NR battery charger red light flashing to indicate fault. I have a multimeter and want to know how to test the charger. I need a wiring diagram and to identify...
Hi. Its easy to identify the pins out. Put the probes into the socket on the scooter to read the polarity. the two terminals on opposite sides will be the positive and negative battery supply. The pin to one side is to disable the scooter when the charger is connected. This terminal is normally connected to negative when the charger socket is in place.
Most faults like this are caused by a broken wire in the charger plug orv by a faulty connection in the scooter. Sometimes the charger socket is faulty, check for heat damage or melted plastic.
Check the battery connectors. Good luck. Neil.
May 15, 2010 | Health & Beauty
Dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Nov 06, 2009 | Makita 18V LXT Lithium - Ion Cordless...
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Sep 21, 2008 | Electronics - Others
Showing not charging display on screen when we hold for charging the mobile.
cause of the fault sometimes is in the charger it might not compatible with your phone try to use another charger, if the fault remain, refer it to service personel, I suggest it is the charging pin problem try to replace it, or maybe in battery terminal should fix the contact to battery.
Jun 22, 2007 | Nokia 6230i Cellular Phone
Sony Bcg 34HRMF4 Super Quick Charger with Lcd Indicator And 4 Aa Batteries Logo
572 people viewed this question
Top Sony Electronics - Others Experts
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
