Question about Kenmore 75085 Air Conditioner
The ac makes a rattling sound when it cycles on and it spits water out the vents. Not a lot, but enough. What is causing it and what should I do?
    President:
  • 3,773 Answers
Check Drain for water out the back
Clean
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 07, 2010
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
Water and moisture build up
this sounds like the clothes are not spun out enough in the washer. there could also be a blockage in the ducting that would cause condensation bulit up but it sounds like you have a lot of this very unusual
Sep 05, 2009 | Frigidaire Electric Dryer
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
Ac making noise
sounds like the drain is clogged, it usually comes out if the outside of the unit just below the coil in the middle of the back, there may or may not be a hose attached to the front pan below the evaporator, try pressuring it up to blow it out. worst case you may have to remove from the window, disassemble and clean. hope this helps...
Jul 18, 2009 | Heating & Cooling
Car rattles under right side of dash when accelerating
The rattling sound coming from the a/c system may be a sign of a failing blower, or there might be an object hitting the blades.
This can be inspected by an a/c technician, or if you are patient enough, you can check it yourself. Many automotive a/c blowers are located behind your vehicle's dashboard glove box.
Hope this helps.
Jul 02, 2009 | 2004 Honda CR-V
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
AC is spitting out water inside. Where are the drain plugs?
I have the same AC and had this problem. Sludge builds up inside the bottom of the unit from dust and water build up causing it not to drain and the fan spits the water out. Its a fairly simple fix with a philips screw driver and a wet vac. Unplug the AC first. Remove the AC from the window. Remove the screw inside the front panel below the filter screen. Then you can pop the whole front panel off by pulling it with a little pressure. Now you need to remove the 3 screws holding each of the slider panels onto the side of the AC. Then remove the 3 screws on the bottom of the left and bottom of the right side of the AC. Remove the 3 screws holding the bar on top of the AC. Lastly remove the 2 screws on the back of the AC in the bottom Left and Right corners. You can now pull the top cover off. You can now use your wet vac to vacuum out the sludge that is in the bottom of the AC from the right and left side. There's a ground wire that connects from the fan motor to the bottom plate of the AC, be careful not to hit it. I knocked mine off possibly to it having been rusting in the backed up sludge and had to strip the wire and reconnect it.
Jun 02, 2009 | Heating & Cooling
Ac. spits out water in the front and ac., is tilted back ,gets worse as it runs
You need to blow into the drainpipe on the outside of the building to clear the blocked drainpan outlet. This just to make sure that your drain is clear. If the problem persists. Check that the filter is clean. This can also happen if you are slightly short of refrigerant and running the aircon at 18C or lower on a humid day.
Apr 28, 2009 | Heating & Cooling
LG air conditioner spitting out water through vents
Hi Mia
I would worry about coolant .. your problem is that the drain in on the outside is pluged or the AC is not installed correctly and is not draining to the outside as it should...
hope it helps
let me know
Apr 07, 2008 | Heating & Cooling
Kenmore 75085 Air Conditioner Logo
130 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
