Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Does not hold water just drains as it fills - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • Whirlpool Master
  • 2,605 Answers
Hello, Welcome to FixYa.
Here`s what I find is most common when dealing with the symptom you`ve described.
I'd suspect the drain hose is lying down on the floor or is pushed down into the stand-pipe too far.
If the drain hose is below the water level entering the washer it will siphon out immediately. The drain hose must be above the highest point the washer has to fill, ( refer to your manual, but it is typically recommended to be about "48 to "60 in height )
Also if it is in a stand pipe insure it isn't pushed in too far, just a few inches and then secure it without completely covering over the opening or that too will cause it to siphon.
So inspect your drain hose. Let me know if this was indeed the case and if so please rate the solution accordingly. If not we can move forward from there.
Thank's for coming to FixYa and good luck.
macmarkus :)
Posted on Aug 07, 2010
  • ropersmom Dec 22, 2010
    I don't know why this makes a difference, but it does. I pulled the drain hose out and my washing machine filled as normal. The hose was pushed way down into opening. I pulled it out until just a couple of inches was inserted. Works wonderful and no repair bill. :-) Thanks!!
Keystone Raptor 3110TT 2007 and fresh water holding tank. What size PEX cap do I need to prevent water from running out of my drain. Can't fill up water holding tank.
The water tank drain should have a shut off valve to prevent water leak. I wouldn't cap it, you should want to drain water tank on occasion.
Mar 21, 2017 | RVs
Dishmachine will not hold water. Its draining as you fill it?
0
Does not hold water Faulty #3 micro switch (drain) Replace switch, P/N 00411.00
Clogged or defective drain valve Clean and/ or replace drain valve, P/N 04113.00
Nov 11, 2011 | Cma Dishmachines L-1X Dishwasher
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
Can not hold wash temps at 150 degress F.? Once filled the resorvior tank stays filled, but water continues to run out main drain?
If it's drain water and filling with water at the same time your drain hose is lower than the water fill line of the washer. try raising the drain hose up higher
Jan 26, 2010 | Hobart 42 in. AM14C-154 Free-standing...
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
Continues to fill, not holding water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
If the above adjustment doesn't produce positive results, replace the control.
May 31, 2009 | Crosley Washing Machines
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
176 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
