Question about Compaq Inkjet IJ750 Printer
I only have the black cartridge. Can I print without installing a color cartridge?
  • 506 Answers
If the coloured cartridge is completely dry you may not print just from the back ink only.
Posted on Aug 07, 2010
Can I print black and white without having color cartridges?
You need to have color cartridges installed for your printer to function. You can however print black and white with empty color cartridges. If you do this you may damage the print head and not be able to print in color again. If you can live without color printing I recommend a monochrome laser printer. It will never print color, costs 1/2 as much to print with, won't dry out, and the cartridges last way longer than ink cartridges.
Sep 28, 2010 | HP Officejet 6500 Wireless All-in-One...
My printer has been printing for 3 days in a row now WITHOUT a black ink cartridge inserted! How is this possible? It prints black text alright, so it cannot be the color cartridge in there doing the...
If there is no black cartridge installed and the printer is printing "black", it's not true black. The printer combines the colors to make black. I didn't think that it would print at all with a cartridge missing. Learn something everyday!
Sep 17, 2010 | HP LaserJet 3050 All-In-One Printer
SCREEN READS "INSERT RIGHT CARTRIDGE" ONLY THE COLOR CARTRIDGE IS LOADED. CAN'T I STILL GET IT TO PRINT??????
No..! you need to install the black cartridge..!
The printer needs to be aligned with both the cartridges no matter if they are empty or full. So even if the black cartridge is empty and the color cartridge is full. The color will print and the black wouldn't.
But if you install only one cartridge it will not work as i said that the printer could not align to the cartridges unless both the cartridges are installed.
On some printers if you install the black one only it works. Without installing the color one. But on this printer It is mandatory to install both the cartridges together other wise it will give you error codes.
This model needs the cartridges to be aligned and then print and if you see inside the printer it has a carriage holder for two cartridges which moves back and forth to print.
So install the black cartridge and it will work perfect.
May 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Orange light flashing next to down arrow and printer won't print. just says that color not installed. i have changed print settings to black only and installed a new black cartridge
It will not print without a color cartridge installed, even if you only want black. It will need a color cart. as well, and it can't be empty. All of the printer companies are doing this now. Wish I had better news...
Jun 24, 2009 | Canon PIXMA iP1800 Printer
Can I operate my HP v40xi without a color cartridge?
I would like to inform you that there is no way to print with black cartridge alone. You need to install two cartridges to wok the printer. So I recommend you to install color cartridge and change the settings to print in black only.
May 22, 2009 | HP OfficeJet V40xi InkJet Printer
Print cartridge missing
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below:
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 13, 2009 | Lexmark X2650 All-In-One InkJet Printer
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
How can I print a color picture without using a black catridge?
Black ink is an essential part of the printing process. The black color is only made by the black cartridge, the color cartridge does make "black".
One or more optional photo cartridges may be available, depending on your printer model.
  • Use the photo cartridge with a tri-color cartridge for best-quality color photos and graphics, and sepia or antique photos.
  • Choose a gray photo cartridge to print black and white photos with truer grays and richer blacks.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 21, 2008 | HP DeskJet F380 All-In-One Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Print black w/o color ink cartridges loaded
No, in general all current inkjet printers require the installation of a color cartridge even if you want only black printing.
(If you had an old cartridge "Empty", you might be able to purchase a resetter (Epson) and set you printer to print in black only.)
You can, set up your computer to print in black only by selecting Mono printout in your print set-up.
There are a few Canon printers (Older) that used to print in Black or Color only printing....but no longer available......
Feb 09, 2008 | Office Equipment & Supplies
Compaq Inkjet IJ750 Printer Logo
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Computer Links
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
