I have a moffat 2030 automatic oven which is around 15years old and it has stopped working as automatic so i cannot use the timer. From where you think I can get a service manual due to I did not find anyone who can fix it here but i am sure that if i have the service manual i will fix it myself.
  • 9098 Answers
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
You can find helpful exploded view diagrams and order parts by entering your full model number here:
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
  • 25 Answers
SOURCE: Moffat Electric oven
check your breaker
Posted on Dec 12, 2007
  • 3 Answers
SOURCE: moffat oven
U need to open/unscrew back and look at bottom connections to the left ( looking from the back) Earth green and yellow- Blue is neutral and Brown is live you probably need electrical female spade connectors for your end of the 'hard' wire !!
Posted on Dec 21, 2008
  • 78 Answers
SOURCE: sears kenmore manual oven timers
You can take the back off, make sure power is off, take the two wires off completely, it will be completely off, then go to ebay find you a timer and have it shipped to you and replace it
Posted on Feb 18, 2010
Testimonial: "thanks a bunch (of silence)"
  • 351 Answers
SOURCE: transfomer works, timer dosent
If the timer is stopping, it could be a physical obstruction. Or it could be an electrical mis wiring so that the timer is turning itself off at that point, check the incoming wiring and see if it makes sense, and follow the diagram to see if the incoming power is definitely not on any switched terminals, they would maybe be marked with NO , NC,
Posted on May 04, 2010
Testimonial: "thanks will do"
Moffat oven doesn't heat .The elements don't turn red
Check the oven fuse. If that's OK, unplug it from the power supply. Remove the screws holding the element to the oven and pull it carefully back away from the oven wall. Connect your VOM test leads to the 2 terminals (meter set to at least 250Vac). Make sure the leads are not touching any metal parts of the oven and they are not touching the element. Plug oven in and turn the oven on. Do not touch the oven during testing. Reading 220 - 250 Vac power is OK. Element is bad. Reading lower then 220 or none at all no power getting to element, need more testing to find the problem. Be careful, and use common sense when working with and around electricity.
Feb 05, 2015 | Moffat Ovens
Oven does not work. (former tenants did not report this
sometimes it could be in the clock ......make sure is set to manual and not waiting for the timer to be set , obtain a manual if you could , hope this helps
Nov 02, 2013 | Moffat Ovens
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
1952 Moffat Bake Stove
I have a working 1952 moffat stove with warming oven if interested
Oct 27, 2009 | Kitchen Ranges
I need a operations manuel for and E32 moffat
Try this site.
If this isn't it let me know and I will keep searching. Hope this helps.
Aug 27, 2009 | Moffat E32 Full Size Electric Convection...
Problem with oven on Moffat Program Gas Cooker
Sounds to me like the oven thermostat has gone.
Dec 30, 2007 | Moffat Ovens
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
