I put in a disc and no options are coming up on the screen and the disc is not reading burning nor burning cd
  • 506 Answers
Try and access the CD-ROM drive from My Coputer folder. If the CD can be read, that means that auto run is disabled on your system. If still you cann the read the CD, then there is a problem with your CD-ROM drive. Try cleaning the CD-ROM drive lens with the appropriate cleaning kit.
Posted on Aug 07, 2010
How do I format a dvd disc
You don't have to. DVD's and CD's are already formatted from factory. But if you are having problems to record on (burn) them probably your computer is not capable for DVD burn, just CD's. But if it is equipped for burning then try this:
See alsoFormat a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
Nov 30, 2011 | HP Computers & Internet
I put in a dvd/rw disc and it will not read it. in My Computer it comes up as a blank disc (cd)
Make sure the discs you are using are compatible with your drive. Some drives will burn dvd - r discs but not dvd + r discs. Hope this helps.
Jun 09, 2011 | Lite On LH-20A1H DVD RW Dual Layer Burner
I have a Plextor PX-820SA DVD-CD internal burner. The drive reads and writes to CD's, but will not read or write to DVD's (I have tried several different types/brands of DVD media). Please...
this might be because you have not selected the option to burn an audio or data dvd or your burning software does not support dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
May 30, 2011 | Plextor PX-820SA DVD±RW Dual Layer Burner
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
Cyberhome dvr 1200 doesnt read disc
its lazer is either burned out or too dirty to read the information on the disc try putting a lazer head cleaner through it
Apr 20, 2010 | Cyberhome DVR 1600 DVD Recorder
How we make a write protected cd through nero ,explain step by step
1. Open nero burning rom and select the type of CD or DVD you wish to make 2. Put the data in that you want to burn 3. Click next and you will see a screen with burning options 4. Select Finalize disc (No further writing possible!)
You now have a disc that is write protected.
Here is a picture of what the option screen looks like: http://www.samplex.org/wp-content/uploads/2007/09/nero4.JPG
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
Jan 21, 2009 | Ahead Software Computers & Internet
Won't read mp3 and wma cds
The discs were not "finalized" or "closed" - place the cd's back on your computer cd-rom drive and search the help file of your CD burning software and search for "closing disc" or "finalizing disc." Some programs will allow you to close or finalize after you have already burned them, but others (Sony SoundForge is one exmaple) will not allow it - you may have to re-burn the discs and select the option that says "close disc after finishing" (this option is usually left unchecked by default, because closing or finalizing a disc prevents you from adding any new information to the disc).
-Tha Mp3 Doctor
Jan 02, 2009 | Panasonic CQ-C300U Car CD/ MP3 Player
Downloading and burning on a compaq presario 2100
If u want Burn the Music CD just select the option copy disc option and it will copy all data to memory then it will automatically ejects and ask for a blank disc just remove the music disc and insert it with a blank disc it will start writing i.e, burning then finally it will come out and u r music disc is ready
U have lot of software to burn a disc most commonly used is
NERO
Windows default Windows Media Player
ROXIO
If u Have any doubt or a clarification please describe the problem Clearly
Oct 06, 2008 | Compaq Presario M2000 Notebook
CD burn
I Think Your Best Option Would To Get In Contact With Your Laptops/Pc's Make , Im Sure They Will Be Able To Help You (:
Kind Regards,
Jessica Fyfe.
Aug 31, 2008 | Acer Aspire 3050 Notebook
Computers & Internet Logo
78 people viewed this question
Alun Cox
David Payne
David Payne
