Question about HP Office Equipment & Supplies
Trying to print 6x9 envelopes using hallmark card studio and it tells me mismatched
3 Suggested Answers
  • 4 Answers
SOURCE: HP Photosmart 6150 AIO
Sounds like it might be the same problem I had on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Posted on Dec 18, 2008
  • 16410 Answers
SOURCE: Cannot print 6X9 Greeting Card Envelopes. Machine
The sensor for the paper type cannot see the paper. Try moving the envelopes to one side or the other.
Posted on Dec 21, 2010
Unable to install hallmark studio 2009
Virus hit my computer. Now that I'm trying to install my Hallmark Card Studio 2009 a pop up says I have a 1305 error. What to do
Aug 03, 2010 | Hallmark Card Studio 2009 Deluxe Full...
Unable to use Hallmark Card Studio Deluxe 2010
I'm having the exact same problem. I too have spyware doctor. Have you had any fixes?
Mar 07, 2010 | Hallmark Card Studio 2009 Deluxe Full...
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
My printer always refuses to print a 6X9 envelope by showing the message "paper mismatch,Press OK to cancel job".
go to the printer's preferences, and change the paper size. also be sure you are putting the envelope on the correct side of the printer's paper tray. It should have a small picture showing you the way it should be facing, etc.
Aug 14, 2009 | Office Equipment & Supplies
I get a paper mismatch when trying to print envelopes in Stamps.com, what can I do to fix it??
SPENT THREE HOURS DOING THE INSANE OVER AND OVER AGAIN. THEN I DECIDED TO TELL THE STAMPS.COM CONFIGURE THAT IT PRINTED A TRIANGE WHEN IF FACT THE PRINTER ERROR MESSAGE"Paper mismatch.” SHOWED UP ON THE HP MESAGE MONITOR.
I THEN CONTINUED THRU THE PROMPTS ON STAMPS.COM SOFTWARE AND CONFIRED THAT "ALL FOUR" ITEMS PRINTED ON THE ENVELOPE WHILE IN FACT IT DID NOT. THIS GET YOU THRU THE "CONFIGURE PRINTER" SETUP. THEN I SELECTED "PRINT PREVIEW" AND PRINT TEST ENVELOPE AND IT WORKED!! HOPE THIS HELPS. I HAVE NOW PRINTED 30 ENVELOPES,ALL OK.
HP J6480 ALL IN ONE PRINTER
Jul 06, 2009 | HP Office Equipment & Supplies
Hallmark Card Studio Express 2.0 problem
When I try to run Hallmark's Card Studio Express 2.0, I get the "Hallmark Card Studio Express 2.0 has encountered a problem and needs to close" message.
Dec 15, 2008 | Creative Home Hallmark Card Studio 2008:...
Printing card envelopes
It sounds like you may have a size mismatch in the settings. Please refer to this link for information and the settings that you need to verify. You should be able to refer to the packaging for the envelope size to select.
Hope this helps. Please rate this information.
Thanks
Nov 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Jul 29, 2008 | HP Officejet 6310 All-In-One InkJet...
88 people viewed this question
Seeker5211
Seeker5211
