Question about Briggs & Stratton Garden
I have a twin cyl.briggs but has no spark - Briggs & Stratton Garden
  • 252 Answers
I pressume you have replaced both plugs?
can you remove the blower cover from the engine and pull the wires that connect to each of the coils ( these are the kill wire leads) make sure leads wont get caught in flywheel and try starting engine
if now starts could be shorted diodes in harness or earth wire making contact when it shouldnt
if it does not start possible coils have been damaged by d/c current from faulty igntion switch or incorrect wiring
if diodes shorted they will need replacing and have the ignition switch checked
Posted on Aug 08, 2010
Briggs Twin opposed 402707 16hp hard to start because it always starts on 1 cyl. the other cyl fires a little. good cyl. is 80psi bad is 70psi. Runs fine when warmed up. air fins are clean. when turned...
Hello John,
Is your spark weaker on 2nd cylinder? If thats the case I would replace the magneto. If spark is equal on both I would look at valves.I am willing to bet it is valves. I would check valves and adjust gap and try again. You could also set air gap of magneto also, but I think it is valves.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 27, 2013 | Briggs & Stratton Garden
22 hp ohv misses under load comp.ok valve adj.ok spark,fuel,air,ok w.t.h.
really sounds like a carb problem if it only starts acting up under load
Aug 30, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Fitted new coil to briggs and straton 16 twin but have no spark
unplug the wire that comes from the tractor then check for spark if you do then stat by checking he safety switches
Mar 30, 2012 | Briggs & Stratton Garden
I have a 1 year old kohler command pro ch740s. i pulled plug wire off one side and cant get any spark. i pulled other side off and motor dies. can you tell me what would cause one side not to get any spark
hi there, pauly46 here
from your model type ch730 25 hp 0040 it seems that
this model does not need or use a smart spark ignition module
please check that you dont have a kill wire from your coil groundin somewhere between kill tab on your coil and the ignition switch
then if you still have no spark replace the ignition module
that has no spark - your engine has been running one 1 cyl
as soon you pulled the h t lead off the firing cyl the engine died
that tells you no fire on other side
i am sure these units do not use any diodes fitted between l/h and r/h kill wire tabs leading back to ignition switch , i think these are mainly on briggs vee twin
here is web site for service manual
http://www.kohlerplus.com/main_frame.asp
enter as guest on the site
go to command pro twin
go to service manual section
select SM-24-690-07 ( replaces tp-2450c) from the list
download a copy and print
cheers hope it helps
pauly46
May 01, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
115 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
