Question about Motorola Mobility RAZR V3
Won't charge & can't recieve pics
Phone won't charge. says charging then goes blank, when powered off. also, when powered on, won't recognize charging at all unless plugged into computer.
second problem... can't get download of pictures when they are texted to me.
    Brigadier General:
  • 7,752 Answers
The board is corrupt with bad files ....you will need to take phone to a mobile repair center and have them reflash the firmware on the phone for you.
Posted on Jun 29, 2008
IPhone won;t stop vibrating ,blank screen won';t charge help ??
If phone was dropped or got wet, it needs to be taken to a tech ASAP. Try restoring it, putting the device on DFU mode.
Nov 01, 2014 | Apple For iPhone 4/8GB LCD Screen...
Phone won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 28, 2012 | Pantech Pursuit Cell Phone
Safelink phone won't charge
my phone does not show that it is charging.i called safelink and told them about the phone she told me it as charging..
Jan 08, 2012 | LG 500g TracFone
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
I let my phone battery die yesterday and now when i try to charge it it says that the charger is attached; but when i try to charge it and turn it on it only goes to the main motorola screen with the...
yes of course, you need a new battery.
when you get this battery, also buy a universal charger.
do not insert the battery into the phone until you charge it for 3 hours with the universal charger.
after that the phone will work very fibenluis_14.jpgne.
Jan 27, 2011 | Motorola Mobility Clutch i465 Cell Phone
9700 will not charge, boot or show any signs of life. New battery and charger.
Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
5: picture download phone to computer:I don't know anything about a disk, but I got my pic off my phone with a usb cable and my computer recognized it. I run with Media xp. Now on my older PC I just sent the pic to my t-mobile account and them sent them to my photo ablum. It's a drawn out process and take more time then the cd, but like I said I never got a disk with my phone neither. I hope this helped
REINSTALL SOFTWARE:Dear customer,
Try to use the code *#7370# to do a master reset on ur N70, this usuauly works. Or else try formating the phone , press (send + * + 3) keys at same time then press power key until power on and keep pressing the three keys for 40sec. If the above given solutions dont have the desired effect then you have to search for cracked phoinex software and flash your phone with USB cable if still the same then it is hardware problem ( either faulty OMAP or faulty RAM
Jul 16, 2010 | RIM BlackBerry Bold 9700 Smartphone
Network, Not charging,
It is clear to say that your phone is dead right? Just want to clarify first, did your phone experienced an undesireable thing before it does not recieved anymore signals and dont charge? Okay..Lets presume that it goes that way. So what I want you to do is to make an operation on your phone. Remove the battery and sim. Place other battery into your phone and then connect the charger. If it is charging then this will lead you to an idea of what is really happening of your phone. We might consider the battery is faulty. Place the sim back into your phone, power up. If you see that it is catching signal then your phone now is okay. But if none of this make things right then I suggest that you go to an cellphone repair center so that your phone will be check its hardware system.
Dec 22, 2009 | Nokia 2650 Cellular Phone
Blinking red led while charging and tries to turn itself on but screen just goes blank and keeps charging
This can be caused by the fact that you ran your battery so low that when its charging the phone tried to turn itself on but loses all power instantly and dies try charging the phone through the computer you might have better luck with getting it to run properly.
Kyle
Jul 09, 2009 | RIM BlackBerry Storm 9530 Smartphone
Battery shows 24.8 volts no power
Yes, your batteries are trashed. You need to replace them. Or take them off the chair and put them on a car charger,slow charge. They need to be up over 24VDC. If they fall under 24VDC the charger won`t recognize them and won`t charge.
Mar 30, 2009 | Golden Technologies Buzz Around 3 Wheel...
W380 goes blank when connecting via usb in files transfer mode
Finally I got it to work. I had to fully charge my battery as I had noticed that when i was trying before the computer was trying to charge the battery. Once I had fully charged the battery and then attatched it to the computer put it into file transfer mode it was really easy. Anyway I hope you have managed to solve your problem.
Nov 20, 2008 | Sony Ericsson W380i Cellular Phone
Motorola Mobility RAZR V3 Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
