Question about Bosch Dishwashers
I have a Bosch Dishwasher SHU3302UC/14 that will not drain. We initially thought the problem was the disposal because water kept backing up into the sink. We replaced the disposal, removed the dishwasher plug in the disposal, but the dishwasher still does not drain. I would like to check the drain line, but am unable to access it. I removed the kick plate and the screws that secure the dishwasher to the underside of the counter, but the dishwasher will not move. Can you access the drain line from removed the drain in the bottom of the dishwasher?
    Top Expert:
  • Bosch Master
  • 27,248 Answers
If the sink backs up then it is likely there is a blockage in the drain, not the dishwasher outlet.
Posted on May 01, 2017
  • 11 Answers
SOURCE: Danby counter top dishwasher leaks
This might help with disassembly. Mine was leaking also, but my main problem was no spray. Use my disassembly instructions to remove the pump/motor. If you notice that the leakage is from the pump and not a loose connection, remove the pump cover and apply a thin bead of Blue RTV sealant to the rubber ring. This stopped the leak in my pump.
________________________________
My Danby dishwasher (DW) stopped working. The spray arm stopped spinning completely and very little water was coming out of the arm. When I removed the spray arm (CAUTION: reverse threaded, turn CW to loosen and CCW to tighten) and ran the DW, very little water was spraying out of the pump.
I thought maybe the pump was clogged. So, I followed the recommendations I had seen online about running a few cycles with Vinegar to clear the crud from the pump, but this did not help.
It seemed like the motor was operating, and there were no strange smells to indicate the motor was burned…just no water spraying. So I thought it must be the pump. Before disassembly, I tried to locate a replacement pump. I searched far and wide, both locally and online, and could not locate a replacement pump. So with nothing to lose, I decided to disassemble the DW, take a look and see what I could find. I am glad that I did.
The bottom line is that I disassembled the dishwasher and found that the plastic pump impeller had worked its way off the pump shaft and was not turning. I forced some Teflon plumbers tape over the shaft and forced the impeller back onto the shaft. The impeller has a flat spot to line up with the shaft and I pushed the impeller down on the shaft as far as it would go. I then used a small socket to fit over the shaft and GENTLY tapped the impeller for a final seating. I reassembled the dishwasher and it worked like a charm.
Since I could not find any service manual or instructions online for this DW, I thought I would share my disassembly/reassembly procedure.
Since my instructions are too long to post here, a complete repair document including a link to pictures can be found at:
http://www.megaupload.com/?d=XBOGBR4I
Posted on Jul 27, 2008
SOURCE: Dishwasher drains into sink
As background, the dirty water typically goes from the dishwasher to a small tube within a tube, and that goes to the disposal. This ensures that your dishwasher does not back up in the event of a clog.
The problem is likely that the tube that links the thing you see next to your faucet to the disposal is either totally or, more likely, partially blocked.
I recommend taking the entire flex pipe off and inspecting. In my case it was about 80% blocked, so a simple test whereby water was pored down failed to show the issue.
Once I took it apart and gave the tube a plumbing version of an angioplasty all was well.
Posted on Feb 25, 2009
lou5577
  • 21 Answers
SOURCE: Bosch Dishwasher SHU3302UC manual
I have one it seems forever ,about 45 mins
Posted on Apr 22, 2009
  • 250 Answers
SOURCE: bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Posted on Feb 21, 2010
NoMorTosh4Me
  • 17 Answers
SOURCE: Any known problems with Bosch
Go To The Bosch website and get the info on the recall for the faulty controller which may cause a fire! This model is on the recall list!
Posted on Oct 18, 2010
My Bosch dishwasher SHU43C won't fill. husband used plunger in kitchen sink many times throughout the day. we didnt realize the water was being forced back down the dishwasher drain valve and filling the...
You need to clean that contaminated out of the dishwasher and clean the water level float and the screen at the bottom of the washer tub.
Jul 13, 2017 | Dishwashers
Water overflow then no water
It may be a sticking float switch. The float switch controls the level of water in the dishwasher and if it is sticking on or off it could cause them problems you have
part numbers 263834 and 263185.
Hope this helps
Jan 02, 2014 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Water doesn not drain out
The problem is most likely that there is still water residue at the bottom of your machine.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again. Also check that the drain pipe is not kinked or caught somewhere.
Feb 17, 2011 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Shu3302uc water comes out bottom of door when running
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Apr 14, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
I have a Bosh SHU3302UC dishwasher that seems to be pumping all of the water out of the basin and will not advance to the next cycle. I know it is normal for the washer to pump to the drain at the...
Make sure you go to the Bosch website and follow the recall notice on this model...they have a recall repair notice that replaces the faulty controller on this model...the faulty controller may cause a fire so be sure to stop using the unit until you setup the recall repair appointment...I hope this helped! (We just found out about the recall...they never contacted us even thoughwe registered our unit when we bought it! Figures!)
Mar 07, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosch dishwasher won't drain model SHU3302uc/17
probably something stuckin drain pump. remove plastic part in bottom of unit with a torc screw driver spin the propeller and your problemis solved. let me know if it works.:]
Dec 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
After two to three days the water starts to appear
hello mam
please check the solenoid walve which controls the water to check this please open the top cover of the washer and see the water line where the water hose pipe is connected there you can find the solenoid walve and observe this as you give the supply and timer switch is ON you hear the sound of the walve operation while it opens the line to take the water and as switch of the mains it should shut the water line to stop the intake of water and if this operation is not happen then please change the solenoid walve.
Oct 07, 2009 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Feb 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
71 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
