Question about Sport & Outdoor - Others
I have a Johnson 30 hp outboard. When I turn on the ignition, the starter motor spins but does not engage the flywheel. I thought it might be low juice in the battery but that was not the issue. Any suggestions? LB
  • 11,896 Answers
On the starter there is a little gear that will shoot up to the flywheel when it turns. Sometimes this gear can stick and not go up. Then it needs to be pried gently loose and lubricate the shaft that it rides on.
Posted on Aug 07, 2010
Evinrude motor problems
The stater gear is thrown up by the quick spinning of the starter motor. It is on "ramps" that move it up. They can get corroded or gummed up. It should have a very light or dry lubricant on them.
Also if the motor is worn it may not accelerate with enough "snap"
If the battery is weak or the connections are corroded, you can get the same result. Hope this helps.
Jul 27, 2014 | Johnson Evinrude Starter-Outboard -92...
Starter relay ground
Usually if the starter spins but does not engage the flywheel, the problem is the flywheel or the bendix drive in the starter. The starter gear is supposed to extend to meet the flywheel when the starter spins.
Apr 24, 2013 | Alfa Romeo Cars & Trucks
What is the gas mixture for a 9R-70C?
What a neat little fisher motor. All needle bearing motor so you can run it on 50/1 --would use synthetic for the best operation. Take care of that starter spool- slowly engage the plastic gear to the flywheel before you pull the starter for the start.
Aug 06, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
Out on boat when starter motor on mercury 70hp 3cylinder stopped working.back on shore took it off and put it back on.when turning enine over starter seeems to spin in wrong direction and not spinning up...
Spin Backward? that's not good. Would check the battery connections. If backward- you may have other problems associated with backward battery connections and ignition systems. If it's just an optical illusion- you should try to bridge the starter solenoid with a jumper to the big terminals and see if the starter is really bad or just a low battery. If your battery is down, your charge system on the motor may be giving you trouble.
Your starter when sitting on the bench and directly hit with 12 volts should jump substantially with the torque. If it just spins like a fan motor- it's shot.
If jumping the solenoid makes it work, thats the problem. But clean or replace the cable ends on the bat and solenoid first.
Just a note: you should be able to pull start that motor by wrapping a noted rope round the pulley on top of the flywheel. If you ever get stuck again. Just watch where the knotted end of the rope goes.
May 03, 2011 | Mercury Mark 30 Hipo Outboard Motor...
The starter will not engage to the flywheel on a 1990 Johnson 25 HP Outboard. The solenoid works but centrifical mechanism does not.
Try spraying some CRC Light lubricant on the spiral where the pinion gear slides up and down. Can you turn the gear so it will move up to the flywheel? If it turns and stays at the bottom, you will need a new pinion gear! Does the starter motor spin?
Sep 06, 2010 | Boating
Does an 85 johnson outboard motor 15 hp have
Not ignition points as a set of breaker points as we know it.The timing is set from magnets set under the flywheel.Hope this helps
Sep 02, 2009 | Sport & Outdoor - Others
I have a 50 hp 1975 Johnson outboard. When I turn
There is a switch in the control box that locks out the start unless you are in neutral. Open the box and put in a new switch,this is a safty device to keep it from starting in forward and throwing you out of the boat. Jim OMC retired Mech
Jul 07, 2009 | Boating
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Sport & Outdoor - Others Logo
41 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
