Question about Health & Beauty
I have a Sta-Rite Duraglas above ground pool pump and need installation manual on it. can you please give me a website i can go to forinformation please
  • 8,197 Answers
You can get the manuals on the link below.
Owners/install manual.
http://www.electricmotorwarehouse.com/PDF/dynaglas_manual.pdf
Good luck and please rate 4 thumbs up for the free answer
Posted on Aug 07, 2010
What bearings do I need for a sta-rite JWPAS5F-2A4
there is a possibility it might use the most common 6203 2rs or 6203 2rs 5/8 bore, these are a hard motor to work on, you must be careful pulling the front bearing as it is easy to bend the threaded portion of the shaft, and breaking or bending/breaking the start switch is always a possibility, and these parts are near impossible to find ! I wish you the best of luck... jay
Jun 16, 2014 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
How to clean or remove impellers in sta rite pool pump
remove band clamp then remove the part over the impeller then the reverse screw holding the impeller on then unscrew the impeller regular thread hold the back of the motor shaft take apart remove old install new and re assemble
May 16, 2014 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
How to prime sta rite pool filters
put water in pump basket and turn on after opening valve 1 at a time
Nov 03, 2013 | Sta Rite StaRite DuraGlas Pump 34 HP...
I just installed a new UQS1153R motor which replaced the original motor on my pump. I connected all of the electrical leads as the original setup. I can only get low speed on both the low and high speed...
Your high and low speed should be the same leg of your 220v and the common will be the other leg. You will need to isolate these to be sure the common is on the common lead of the motor as the wire plate may well be different from the old motor.
I hope this helps, if not write again.
Aug 14, 2011 | Sta Rite Sta - Rite Duraglas In - Ground...
I have a sta rite model # p2ra5f182L. The pump is about 6 yrs old and sounds like the bearings are getting ready to go. Can I replace the motor or should I replace the the whole unit?
this is the best pump out there. ya fix it !look for your local pool pump repair guy and have him do a bearing job on it about 75.00.. i love these pumps. when you pick up your pump ask him how to take better care of it..... jay longwood florida
Jan 29, 2011 | Sta Rite StaRite Duraglas Pump 1 12 HP...
Where can a find a new pump CHEAP? Current pump is Model C48L2P104 (18 years old). Serial 1B93. Voltage 230 HP 1.5 RPM 3450/1725 Amps 9.2/2.5 Frame 48Y Dura-glas H/L
A new motor and pump parts (if needed) would be cheaper than a whole new pump. Your motor is part number UQS1152R or if you just want a single, high speed motor you could use USQ1152 to replace it. You will likely need a seal and seal insert as well; part number 100 (it may have letters in front like AS100, PS100, etc) and J3-2. A whole new pump you should shop for part #P2RA5YF-182L.
For a quote on the parts from us you can contact us using thru our website at www.arrowpools.net. Otherwise, google those numbers to locate your best deal.
John
Jan 04, 2011 | Sta Rite Sta - Rite Duraglas In - Ground...
I lost the gasket that seals the 2 halfs of a duraglas P2RA5E. Would you have a part number
this is the best pump going ! I hear a guy is going to list one on ebay for $5.00 shipped, MONDAY the part # should be STA-101-3745G retails for about 15.00..
remember to prime that pump !!!
Jay.. the pool pump repair guy in longwood Floida 32750
Nov 20, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
Need bearing within PN C103-137P1 , higher assembly would be P2PA50-120L
most of these are 6203 2rs c3 bearings used in this motor. here is a picture on how to remove your pump for service, i would suggest professional repair to avoid extra costs.. just search your area for yoour local pool pump motor repair guy..remember to prime the pump after any pump repair ..jay
Sep 21, 2010 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
