Question about Whirlpool Dishwashers
The "clean" light is blinking - so the dishwasher isn't working.
  • 4,323 Answers
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then it’s an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Please post back for further assistance.
Daniel
Posted on Aug 08, 2010
djz83
  • 88 Answers
SOURCE: Dishwasher will not work
This usually means a couple of things there could be a heater problem, water valve , or pump problem.
Posted on Jan 11, 2009
  • 11 Answers
SOURCE: Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Posted on Feb 05, 2009
Greg20
  • 149 Answers
SOURCE: Clean light blinks, dishwasher won't start,
turn the power off at the breaker for 10 minutes and check it then.
Posted on Jun 11, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore dishwasher model #665.17034401 --- Clean light blinks
The blinking clean light is an interruption in the dishwasher program that indicates a component malfunction, or it can be a result of a momentary program glitch. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
Posted on May 07, 2010
Testimonial: "Quick response, thorough and very helpful. Thanks, Al"
  • 949 Answers
SOURCE: Kenmore Dishwasher clean light blinks
This is due to a problem with heating of the water. I have put together some instructions on what to do and how to reset the control so you can use the dishwasher. Follow the link below and let me know if it works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
HOW TO RESET THE CONTROL PANEL ON KUDE60HXSS4
My Kitchen Aide Dishwasher KUDE60HXSS4 has the clean light blinking and water is coming out of the dishwasher running down the back wall. The dishwasher will not come on. The clean light just blinks.
Jul 11, 2012 | KitchenAid Architect® KUDT03FT 24 in...
My Kenmore Dishwasher 665.16359301 quit working. I flipped off the breaker then back on again. The cancel light comes on and it sounds like its going to drain but theres no water in it. After about 20...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If still the issue is not resolved then to resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 20, 2010 | Kenmore Dishwashers
It want come on the clean light blinks
its showing an error code check under unit there should be a tech sheet under there to remove error code
Jun 06, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Blinking clean light
This blinking indicates a failure to properly heat the water, the link below will have instructions on how to reset the control so you can use the dishwasher and it will provide areas to look as to why it failed. Let me know if it was helpful.
Blinking Clean light
May 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My kenmore built-in dishwasher "clean" indicator light is blinking instead of a steady light. Now nothing will work on the dishwasher. I've tried to cancel, along with other possibilities and nothing seems...
press heated dry and hi temp back and forth till all the lights light up then hit cancel. You have a bad heater if the clean light is blinking
Jun 15, 2009 | Dishwashers
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishwashers Logo
169 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
