Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
TV turns on and off.
I turn on my Tv and it stays on for about 40 seconds and turns back off for 40 seconds then turns back on. It will continue this way as long as you keep the TV on. The green indicator light stays on during the whole cycle no blinking occures. I've had this TV since dec 03' have had several bulbs replace and the block blog replace. Called Sony and was told that it needed service no know problems. I called a service center and was told two possible problems: replace the bulb or replace the ballist. Could you please help? Oh I did try replacing the bulb but when I put the new bulb in it worked for about 10 hours and Now back to the same issue in the begining.
  • mort22 Aug 02, 2008
    I have the exact same problem and was wondering if I could order a nd replace the balast and lamp easily enough?
  • hammmer94 Oct 06, 2008
    yes i do!! The green light flashes set comes back on after 10 to 15 seconds
    I called my cable company & expect it to be the Box or maybe the cable feed
    from outside.. This is very upsetting the set is not even 2 years old!!!
    What should i do???
  • 87 Answers
It is possible that the ballust assembly is causing the lamp to fail. You likely need to replaced the ballust with a new lamp because if the ballust is bad it has likely already damaged the lamp. If you have been handling the glass of the new lamps with your bare hands this could be the cause of the short lif as the oil from your hands will cause premature failure of the lamp.
Posted on Jun 13, 2008
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
Apr 30, 2012 | Toshiba 40E210U 40 in. LCD TV
Philips tv #51PW9363 turns itself off and on over and over.....
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Philips 51PW9363 51" Rear Projection...
T.V WILL NOT STAY ON: JVC AV-27F702 27" TV
This sounds like a protection system cutting in. This happens if there is a major fault and continual use would lead to a fire risk.
Aug 09, 2007 | JVC AV-27F702 27" TV
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
