Question about Maytag Refrigerators
Our fridge is leaking water to the bottom - there is no water in the drip tray just on the bottom shelf - it seems to be coming from up above and dripping down the back on the inside. Any help
    President:
  • 3,773 Answers
Clean drain starting underneath freezer coils. Compressed air is best but you can use hot water and blow in a tube until it is clear
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 07, 2010
Why is it leaking water onto top shelf
Most modern fridges have an automatic defrost that works by draining into a sort of funnel above the back of the top shelf.
The funnel is connected through the back of the fridge to a rubber drain tube that goes down the outside of the back to a heated evaporation tray under the fridge,
The hose and/or funnel can get clogged with disgusting yucky stuff, and the water spills over the top of the funnel onto the top shelf.
The fix is to clean all the bits. It's usually no big deal to take apart.
I have resorted to blowing through the tube from the bottom end and then cleaning up the mess, and brushing my teeth. Quite revolting but, that's the price I paid to become an expert.
Cheerfuls
Nov 20, 2015 | Refrigerators
I have ice accumulation on the bottom shelf of my freeze of my Maytag side by side MSD2957DE. There seems to be water dripping down from the back inside panel. Is this something I can fix on my own
If you have an ice maker, or water dispenser turn off the water supply to the fridge temporarily, and see if the problem still exist. The solenoid water valves on some of these models accumulate mineral deposits and don't close completely after time, thereby leaking.
Sep 19, 2014 | Maytag Refrigerators
WATER COMING FROM UNDERNEATH SALAD DRAWER
My guess is that the drain tube is still clogged.
Sep 18, 2014 | Hotpoint FFS70 Bottom Freezer Refrigerator
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Kelvinator 330 impression series fridge leaks water internally and runs on to bottom shelf. I cannot see where it is dripping from, the drain rack is clear as is the cooling component. This is a regular...
The drip tray is blocked, open your door, about half way down at the back you can see the drip try, on the Right hand side there is a hole where the water drains, poke a plastic straw down there to clear.
Feb 26, 2010 | Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
Aug 31, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge Leak
We fixed the leak by putting a pipe cleaner down the hole inside the fridge, at the back. This cleared the tube as it had gunk and grime blocking it. Now the water can run freely down the tube and into the drip tray which is at the back of the fridge above the motor.
Jun 12, 2009 | Fisher Refrigerators
Water accumuluation under the fridge
at the back there should be a drip tray if this is full it will leak onto the floor it could be this, it could also be the drain in the fridge is blocked on the back there should be a self made into the back with a hole in it this is to go to the vapure, the part i was on about before, the tank is on top of the pump and its hot so turns the water in to vapour, usually there is not a lot of water but if the pipe becomes blocked it stores the water in the pipe and then lets it go in one full step over flowing the container. to clean the pipe out you can use a flex line or a net curtain rod, push it down and up the hole a few times the blockage will fool to the bottom or come out on the flex.
Jun 15, 2017 | Amana ASB 2623 Side by Side Refrigerator
Refrigerators Logo
118 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
