Question about Samsung RF217ABWP (20 cu ft) Bottom Freezer French Door Refrigerator
Rf217AB Ref. temp contol is blank. one short section of a number flashing on the left display. No temp readings on either but ref and freezer are as cold as usual.
tborn6
  • 700 Answers
SOURCE: ref has no power
First thing to do is to make sure that the plug is hot that your refrigerator is plugged into. Most of the time it's a gfi and it may need to be reset. if youi don't see it there sometimes the electricians will pu it in the garage and or the bathroom but it is still on the same circuit. Hope that htis helps you out.
Posted on Dec 25, 2008
  • 16 Answers
SOURCE: My refrigerator is too cold
sounds like you have a defective temparture sensor
Posted on Apr 07, 2009
HIRAM517
  • 59 Answers
SOURCE: freezer side works fine ref side works for three
CHECK BAFFLE FROM FREEZER TO REFIGERATOE SIDE
Posted on Aug 19, 2009
  • 161 Answers
SOURCE: what temp.should the ref. and freezer be
It says the setting on the inside of the fridge. Just turn the dial.
Posted on Sep 29, 2009
  • 5 Answers
SOURCE: My samsung ref rs2555sl stopped cooling. The
Most of the time if you unplug it from the power source for about 10-15 minutes will reset fridge computer and when you plug it back everything get back to normal.
Posted on Oct 07, 2010
Frigidaire 2004 side by side, FSC23F7DWO flashing error code 2. Now what?
look at the lower half of the back of the freezer wall in the freezer,if you see frost you have a bad defrost heater ,control,or defrost thermostat.make sure the fan in the freezer and cond.enser in back are working. coil under ref may need cleaned,if you un plug for 10min listen, plug in. if you hear humm,and click.over load -relay is bad.
May 22, 2015 | Frigidaire FSC23F7D Side by Side...
I have a indesit fridge freezzer and the freezer part is defrosted and the fridge is stop working and the light is flashing on and of but at the top the lights go of and on displaying 21 c on and of
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 22, 2011 | Refrigerators
Just discovered that the lower freezer section of my LG fridge is working fine bot the upper fridge section is not cooling.what could be the problem
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 21, 2011 | LG LRBN20510WW Bottom Freezer Refrigerator
Flashing "vacuum condenser"
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 19, 2011 | Sub-Zero 650 / O Bottom Freezer...
Viking Ref side by side. Warning light "High temp" went off every 4 -5 days. reset it every time. Today, my ref is making a humming noise and the top right have hot air blowing out, however left...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 05, 2011 | Viking VCSB423 Side by Side Refrigerator
Rm2620 panel control lights are flashing if the temp selected is above level 2. At level 3 and above the on, auto, gas and temp indicator lamp flashes, I hear a click at each flash and if the door is open...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 30, 2011 | Dometic RM2620 Refrigerator
"Service" and "EC-24" keep flashing
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 25, 2011 | Sub-Zero 642
My Frigidaire Gallery display says SY in freezer section and EF in refrigerator section, and the ice is melting
NOTE: This
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
MORE TIPS AND TRICKS:
Leo Ponder
imufo2
Aug 04, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Samsung Mdl #RS265LABP-XAA will cool the refrigerator section, then stop cooling. The freezer section stays cold. I think the refrigerator fans works intermittetly but I cannot find it. Where is it...
Freezer fan located in freezer section.
Try These
NOTE: This
Leo Ponder
imufo2
May 22, 2011 | Refrigerators
Placing a refrigerator in the garage
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Jul 14, 2008 | Whirlpool EL7ATRR Refrigerator
Samsung RF217ABWP (20 cu ft) Bottom Freezer French Door Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
