Question about ATI RADEON X600 Pro, (128 MB) PCI Express Graphic Card
I have installed the card, plugged it in and when i turn my pc on i have no signal from my graphics card, i dont know alot about computers! Please help!
  • swufabuda
    swufabuda Aug 07, 2010
    Were you using onboard graphics before you installed this card?
  • 62 Answers
Try hitting F2 when computer starts. You will get into bios. There will be somethig like "VGA palette snooping". You must enable that.
Posted on Aug 08, 2010
  • bing90020 Aug 10, 2010
    theres nothing about VGA Snooping, im on vista i dont know if its different. i have located where to change priority for different ports but im beginning to think that my ports arent correct. I have one black one that says pci ex and 2 regular pci ports, however my card will only fit in the pci ex port as the other 2 are the other way round!
No signal going sleep
how old is your monitor? can you try to conect another monitor your pc has integrated videocard? does it turn on and beeps?, you should check the back pannel of your pc and try to conect it to onboard video first (if it has), if you get signal get into the bios and change video output from onboard to a external card. if this thing dont work, then vga cord may be damaged or the card is not installed right or not working.
Jun 05, 2013 | Fujitsu Siemens Computers & Internet
No input signal
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya!
Since you had it repaired and transported it home this fault may be due to a loose connection. Or like you say it could be a simple task of placing the graphics cable in the correct graphics output port.
Install the monitor graphics cable into a horizontal graphics output port if possible. Doing this would therefore connect to the Graphics card if one is installed.
Plugging the monitor graphics cable into the vertical graphics output port would mean that you are connecting your monitor to your computer's onboard graphics output. Which will not work if there is a graphics card installed, in which case one must use the horizonal port, found on the graphics card.
If you have checked that the monitor cable is correctly plugged in and your problem continues then one checks the following:
NB: Turn off your Computer before doing the following:
Make sure the graphics card is secure in it's slot, push down on it lightly when the PC is off.
Check that the power connector to the graphics card is inserted: if applicable.
Ensure that the power supply connectors going to the mainboard are seated.
Check the Memory modules, one may need to be seated or cleaned. Clean the gold fingered connectors with tissue paper.
You may also find it of benifit to look at on eof my published works, entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Take care!
Feb 10, 2012 | HP Pavilion Computers & Internet
Hi there. I have just purchased a new ASUS Radeon 6770 graphics card. I have just installed the hardware. When I turn the PC on, I can't get any video signal output from either the onboard graphics, or...
Hi granttoolmad
Shut down computer and disconnect power plug . Extract new graphics . Reconnect and reboot computer , you should get video back . Install the driver with the cdrom you purchased with the card . Shut down . Install new card . and boot your machine . Wait for Windows to recognize the card . Shut down . Connect your monitor to new card . Reboot .
Best regards ,
fanaudi .
Jul 04, 2011 | ASUS Computers & Internet
Parity error :only when im playing games, after playing a game 20 minutes (10 if it has good graphics) the computer screen goes blue and it says "Call your hardware vendor for support NMI: Parity check/...
increase ur virtual memory then for high resolution game u should install a graphics card , nvidia graphics card is the good quality card . After doing that plz check
Jun 01, 2009 | IBM Lenovo ThinkPad R60 Notebook
My screen won't turn on when i start up computer. i have pluged the original grafics card in and pluged the rgb wire in but theres just no signal comein from pc??? any sujestions on how to instal it or...
sometimes the fault is not always from the graphic card ... it could come from the processor or the memory .... please check them too and also check the signal cable especially the pins on the signal plug
May 18, 2009 | Computers & Internet
How to know what is my graphic card
Go to the device manager on the computer and check which graphic card installed on the PC, to do Press WINDOWS KEY+ R, Then RUN will popup, type devmgmt.msc ,so that u can Device Manager.
In the device manager check under the Display Adapters option , hope this help you....Take care BYE.
Apr 22, 2009 | XFX GeForce FX 5200, Graphic Card
Built own tower no signal on monitor screen
TRY NOT USING THE GRAPHICS CARD AND SEE IF IT WORKS THEN. IF SO I WOULD INSTALL THE DRIVERS AND THEN INSTALL THE GRAPHICS CARD.
Dec 26, 2008 | Acer 22" X223w LCD Monitor
I have a HP s3020n slimline the pc is running but not sending any signal to the monitor
Well... try un-plugging the VGA cable... ie., the monitor cable behind the tower...... if u get a message on screen saying No VGA Input... can confirm there is no issues with the monitor...
if you are using graphic card in computer unplug that and connect the VGA cable to normal display card came along with the computer and try...
or if you have another monitor... u can try connecting that to the tower which is not sending the signal to monitor and try....
even then you get the same problem... get an new graphic card... (if you dont have other monitor try with new graphic card)
Aug 24, 2008 | Computers & Internet
Can't see screen to install diver for HP Compaq WF 1907
My friend just purchase this monitor yesterday. When she plugged it in to the back of the tower she received the same prompt u have mentioned. I was able to repair it because she simply did not realize that I had installed a new graphics card into her pc a few months ago. When u do this, you have to hook your monitor into the area where the new graphics card was installed. You can not plug your monitor into the same onboard card that u have previously plugged your monitor into.
Let me know, if by chance, u did install a new graphics card.
Hope this was helpful :)
Jan 30, 2008 | HP Compaq WF1907 Monitor
Diablotek radeon 9200 problems.....please help
OK, turn-off the computer, remove and replace the BIOS battery, then start it up with the VGA cable in the onboard graphics port.
Press the corresponding key to go into BIOS setup (Del?) and go to the Integrated Devices menu.
Change the option from onboard to PCI in the Video options.
Exit and save settings. As the computer restarts (you'll have to be quick) swap the VGA cable back to the Radeon's port.
Jan 28, 2008 | Dell OptiPlex GX260 PC Desktop
ATI RADEON X600 Pro, (128 MB) PCI Express Graphic Card Logo
56 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
