Question about Lincoln Conveyor Oven - 1133-000-A
Lincoln Impenger 1100
I am using an old Lincon Impinger 1100 gas pizza oven. It seems to work just fine, but the temperature only goes up to 598 degrees, and the pizzas are not cooking on the botom of the crusts. Are there 2 burner supplies? I can see one source of flame from one side of the stove - inside. Maybe I do not have the parts on the bootom of the stove positione correctly or, a bad bottom burner? I don't really know how the mechanics of them work, but am willing to listen.
Thank you.
John Hunt/Mountain Man
  • Anonymous Mar 30, 2014
    Cooking flame urns yellow instead of blue
You need 3 fingers on the top blank off 1 hole and 4 on the bottom
Posted on Jul 11, 2008
Hellow my name is ash i sale linclion ovens and repair they have only one burner and they only go up to 600 degree F make sure that the impenger plates one on top and one bottem are possion prapley, 2nd set temp at 500 and 530 f time 6.5 m if still under cook blow use plates with holes
Posted on May 26, 2008
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
Jul 25, 2014 | Lincoln Impinger Electric Countertop Oven...
I have a remanufactured lincoln impinger 1000 gas conveyor pizza oven which I believe was converted to a fast bake 1450 model and the main fan motor on the back is screaming.
If the main fan motor is screaming in your lincoln impinger oven, actually that means the motor is faulty. more so the bearing in the motor are worn out and should be replaced, its easier to replace the motor itself but the motor is very expensive. To save money you can actually replace the bearings your self by opening the back cover in which the motor is mounted, then unmount the motor and disassemble it so you can take out the bearings. take the bearings as a sample to a bearing store so that you can get the size correct.
make sure you get bearings that can handle high temperatures and not those with plastic seals ment for wet or water places.
Apr 29, 2014 | Lincoln Ovens
Pizza not getting crispy on bottom
Clean the fingers and call in the morning
Sep 11, 2013 | Lincoln Impinger 1116 Gas Oven
I have a Lincoln Impinger pizza oven that won't
Yes, it could be, because the heating element is OK
Mar 22, 2013 | Ovens
My lincoln impinger pizza oven keeps showing LLL on temp reader after reaching its temperature,then the temperature keeps rising until it shuts off.
This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
Apr 29, 2011 | Lincoln 1132000U - Impringer II Express...
Does lincoln 1450 series oven do the same job as lincoln 1000 ovn
The 1450 Lincon and the 1450 digital basically does the same things only that the digital is more advance in that it is has mother board whith digital control. it is more acurate in its sttings eg acurate time and acurate temparature setting. It also can give diagnostic massages within the control.
As for your lincoln 1000 series please try and give me the detailed problems, im sure i can help cause i have over 8yrs experinces with lincoln pizza ovens
May 07, 2010 | Lincoln Conveyor Oven - 1132-000-A
I got a 1301 208v the fan blows good but it does
If threre is no alarm please make sure that the gas inlet pressure is ok or contact me at maugoro@yahoo.com
Feb 05, 2010 | Lincoln Ovens
A loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Jul 15, 2009 | Ovens
Lincoln Conveyor Oven - 1133-000-A Logo
534 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
Illassist
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
