Question about Toshiba 36AX60 36" TV
Picture goes black and when i hit the side of the console it comes back on for a few moments
  • gdeberl Aug 11, 2010
    tried that it worked for about 1 day
  • Toshiba Master
  • 11,800 Answers
Bad contact. Take the cover off and reset every single connector, especially the ones that plugs in the video board and  the board that plugs directly in the tube.
Posted on Aug 11, 2010
    tried that it did not work, still goes black and comes back on when I tap the console! When I touch anything on the circuitboard when the tv is on it resets!
  • Azrael SRL Aug 11, 2010
    In that case you have a cold soldering on the console - resolder all of them. And check the grounding wires, one of them is broken.
My Viore flat panel tv comes on for a few moments, then the lamp and temp/standby light flashes and the screen goes dark. The picture is just fine for the first few moments, and then it goes dark. Any
this is caused by a bad connection, or a faulty back light. It is also something you should have a local repair man have do for you if you are not "tech savvy".
Sep 23, 2014 | Televison & Video
Black shadow on 42 inch LG lcd tv its like a ligtht goes off then black lines then picture comes back
You have answered you question yourself:
You have a loose connection inside---may be a plug or connecter inside or a physical problem on one of the boards or even the main display panel.
Someone has to open it and see what they can find by probing the chassis in different areas.
Mar 22, 2012 | LG 42LG30 42 in. LCD HDTV
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Picture goes out
Has the lamp ever been replaced on this TV? If not it would be the first suspect. The next time the picture goes out look for light coming from the back of the TV where the lamp is. If you see no light then replace the lamp. Please take a few moments to rate my answer. Thank you...
Nov 17, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
The dashboard lights on my 2004 Pontiac Vibe go off for a few moments or so and then come back on while I'm driving. All other electrics seem to be working; headlights, windows, radio, windshield wipers....
Fiddle with the dash light dimmer switch - may have a bad spot on the potentiometer. Replace the bulb in the console - probably a bad connection in the socket.
Sep 30, 2017 | 2004 Pontiac Vibe
Wavy White and Grey lines then nothing
The Flyback transformer needs to be replaced on the Deflection Board. It has the big red wire coming out of it going to the picture tube. Becareful with that. Some of them hold a nasty charge waiting to bite someone. Wont kill ya, but it hurts.
Feb 08, 2009 | Toshiba 32AF43 32" TV
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
Screen get pixalated and goes black
HI 99% OF CUSTOMERS THAT HAVE BROUGHT THE 360 IN TO MY SHOP WITH THIS PROBLEM ARE USUALY CURED BY FITTING NEW LASER
May 25, 2007 | Microsoft Xbox 360 Console
Toshiba 36AX60 36" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
