Question about Hitachi 42HDS69 42 in. Plasma Television
Can I use my TV bought in the USA in the UK? - Hitachi 42HDS69 42 in. Plasma Television
  • paullinden1 Aug 08, 2010
    I realise that the voltage is different -so it the frequency of the mains AC. Also the standard TV signal is not NTSC. I am wondering whether my HDMI input will work and what other converter I might need.
  • paullinden1 Aug 09, 2010
    Yes, I understand that. The question is whether I can use the HDMI input in the UK, if I have a transformer for the voltage? Does the difference in AC frequency (50 vs 60 Hz) matter? I'd like a specific answer for my Hitachi 42HDS69
  • 4,102 Answers
Hi, the answer is yes and no, let me explain.
Now if you want to watch tv through the ariel socket in back of telly then this is where you have a problem as the us tv's work at different frequency's but within the next 4 years the uk is stopping using the old analogue signal so even tv's made in the uk will no longer work this way so it would have the same problem as your telly.
Now here is the YES part.
As they are stopping the analogue signal in the and switching to digital then all you need to do is get a free view box and plug this into one of the input ports in the back of the telly and you will then be able to watch digital tv with no problems.
now most people in the uk subscribe to either sky tv or virgin tv they are both subscription based services where you pay monthly and you should have sky in usa or satalite tv what ever you call it over their. now with this you will get a box that will need to be plugged into one of the ports in the back of the telly, so this will be no problem for you and you will be able to use your telly here for free view digital but most people prefer virgin or sky as these have loads more channels and more hd channels, so if your telly has hd socket then you can use this with all uk equipment so, the answer to your question is yes you can use it for free view, sky tv or virgin tv which is our cable tv network, with all of these you have a box that plugs into the telly so you can get the correct signal, this box has the same connection as the back of your telly so you will have no problems using any of these services here in the uk
now for the analogue signal you wont be able to receive this on your telly and to be honest your wouldnt want to as you only get 5 basic channels and their turning the analogue frequency off over the next four years, they have started switching it off in certain parts of the uk but within 4 years it will be gone all together.
so by all means bring your telly over and you will have no problems receiving digital tv which is about 35 english speaking channels or subscribe to sky or virgin and receive hundreds of channels, sky is by far the best as this has the most channels such as all the discovery channels and history and movies and news and sport and on and on and on, with virgin tv you still get loads of channels but not the same variety as sky does.
hopefully that has given you the info you need and if you have any further problems give me a shout back.
if you have dvd players then these wont work with uk dvd's and if you have loads of usa dvd's then these wont work in uk dvd players so if you have loads of usa dvds then either bring your dvd player with you or get an english one that can be converted to play all regions or you could buy a top end one that is all ready region free
Posted on Aug 09, 2010
  • Hitachi Master
  • 12,061 Answers
Usually NO.
However there are qualifiers, and that is if it is an INTERNATIONAL set and will "Do" PAL NTSC SECAM.
USA Has differing standard that anywhere else in the world you MUST check the set carefully. USA is NTSC, UK, is PAL.
Posted on Aug 08, 2010
    President:
  • 1,768 Answers
Yeah, use can use it but you will need an adapter for power because all the power in the UK is about 220 volts and converter is needed.
Posted on Aug 07, 2010
Will my toshiba tv bought in uk work in usa
There are two things you need to know regarding your TV.
Power requirements and broadcasting standards.
1:POWER
Look on the back of the TV and find the sticker or label that mentions the INPUT VOLTAGE.
If it reads 220-240V 50Hz then it will not work in the USA.
If it reads 110-240V 50-60Hz then it MAY work in the USA. At least you know it will work if you change the plug on the mains cable.
2: BROADCASTING
In the UK, broadcasts use the PAL system to display images on the screen. In the USA, broadcasts use the NTSC system to display images on the screen.
You need to check the manual that came with your TV to see if it is capable of receiving an NTSC signal. This signal is used in everything in the USA from PVRs, to DVD/HDD recorders, satellite systems, public access and cable systems.
If your TV meets the power and broadcast requirements then it should work.
May 24, 2015 | Toshiba 50H82 50" Rear Projection...
Please can you advise me; will my panasonic TXP42C2B TV WORK IN THE USA
NO.
This plasma tv has the freeview tuner.
The USA TV needs ASTC tuner.
The electrical power in the USA is 110volts at 60Hz
The electrical power in UK is 240volts at 50Hz
The broadcast signal encoding in the USA is ASTC.
The broadcast signal encoding in UK is DVB-T.
Feb 15, 2011 | Televison & Video
I have LG DVD from UK, now I am USA, when I
U can't mix LG DVD player from Europe with the USA LCD or any orther tvs,because European have different format regions.The format for European are PAL format.The US format are NTSC format.That why ur LCD tv said not supported.
May 15, 2010 | Sony DVP-NS330 DVD Player
Usa DS game won't save,WHY??
It shouldnt matter where it was bought,i've bought a few games when i was in Usa last year and they work on a console i bought here in Ireland.
Try this,this is what i came across before on Prof Layton,
When you go to save a game and the three spaces are used up,select one and overwrite it,you can only save 3 at a time
Hope this helps,
JonnieC
Mar 10, 2010 | Nintendo Professor Layton & the Curious...
Can the format be changed from USA to UK
region codes are different from uk to usa and cannot be changed .can still download games from online to console
Dec 09, 2008 | Microsoft Xbox 360 Console
Will a Nintendo DS bought in the USA be able to play Game Boy Advance games bought in the UK?
Yes a DS from the USA can play GameBoy Advance games from the UK. Like the GameBoy Advance, the DS is region free (so it will also play DS games from the UK
Jul 15, 2008 | Midway Home Entertainment ((Justice...
Help with viewing photos
UK uses PAL system for TV and USA uses NTSC, see if there is a setting in the setup menu to change it to NTSC.
Jun 18, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Nintendo wii
No, USA Region 1 UK Region 2 you will need to buy games from the US or get the Wii Modded to take UK/PAL games
Dec 02, 2007 | Nintendo Wii Console
Magnavox TV not working in the UK
I don't know about the frequencies being different or not, but to get to youse your TV you can use the tuner in an old VCR if you have one sitting around.
Nov 07, 2007 | Televison & Video
Hitachi 42HDS69 42 in. Plasma Television Logo
233 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
