Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Im looking for the fluid that goes on top of bulbs
  • Philips Master
  • 8,617 Answers
Thats CRT coolant. You can get the Phillips CRT coolant kit from www.tvrepairworld.com the kit contains the coolant for all three CRTs and also contains the CD with instructions.
Posted on Aug 08, 2010
Testimonial: "thank you ive had this tv for ever i dont want to junk it just yet"
92 mustang convertable top partially functioning
sounds like hydraulic prob the fluid used in the system sets like jelly over time flush it out and change it to pentrosil fluid .if no luck check the microswitches on the rams
May 13, 2017 | Cars & Trucks
1995 lincolin continental transmission wont shift out of first gear
VSS. Vehicle speed sensor. Although Im sure its already been done but check the transmission fluid. Change it out with new fluid and a filter if you want to and when you do, look at the old fluid and see if its blackish or not pink/red. Look for metal shavings in the fluids catch pan and in the transmissions pan and in/around the filter. The small stuff 1st. Then you can rule out that and move to the bigger stuff.
Jan 03, 2014 | Lincoln Continental Cars & Trucks
Two lower break lights not working (top on in the back window is)
Power for the brake lights travel thru a light failure sensor which could have failed. The third brake light does not involve the sensor.
If both brake light bulbs have no voltage, the sensor may have failed.
Aug 08, 2012 | 1995 Toyota Camry
What kind of bulb do I need for a Philips 55PW9363117F?
The bulbs rarely go bad...instead the clear fluid in the lens goes out making the video look dull. Replace the fluid and you fix the TV. Its a bit tricky so I would suggest getting the parts and instructions from www.TvRepairKits.com
Dec 15, 2010 | Philips 55PW9363 55" Rear Projection...
1994 bonneville break fluid goes where?
you are correct. she is looking at the correct place. later model cars screw the cap on. should be under the hood, in front of where the driver sits.
Sep 18, 2009 | 1994 Pontiac Bonneville
Smoke coming off of tranny of 97 subaru outback
maybe missing dip stick
you did not reference a trans dipstick
Jun 16, 2009 | 1997 Subaru Outback
Wont accelerate!!!
Sounds like a wiring problem and the clicking could be a breaker kicking on and off. As for the surging in the R.P.M.'s I would be taking a look at your throttle positioning sensor. Good luck and remember to rateall the replies you get, thanx.
Oct 27, 2008 | 1999 Chevrolet Blazer
Vanett charging problem
red & white feed to alternator,fed from top terminal of capless bulb in charging light, had a break in it. This is in the plastic tube that goes across the front of the engine in a r/h/d/ vehicle.
Sep 09, 2008 | Nissan Titan Cars & Trucks
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
244 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
