Question about Kitchen Ranges
I have a true life 2600 generator..no manual..what weight oil does it take?
2 Suggested Answers
  • 91 Answers
SOURCE: I have just got a second hand Quadpower Gen 2600 generator
go on line and type in the generators name and the manufacturers site will be there. they should be able to give you the specs and mail or email you a manual. usually there is oil designed for generators since they run at such high rpms for so long and it is found at parts stores and anywhere they sell generators but check with your manufacurer first in case they use something different in your unit.
Posted on Jun 04, 2010
I just purchased a 06 pontiac torrent. no service record. What kind of oil do i use in this suv? It has 100300 miles on it.
Try a 10w 40 weight.
If you live is a hotter climate use a 20 w 50.
The old addage about "once you use synthetic oil you have to for the life of the car" isn't true.
You just can't mix the two types of oil.
Good luck,Gary
Sep 21, 2011 | 2006 Pontiac Torrent
Can you tell me what kind of thread should be used with my Brother XL 2600? I can't seem to download the manual online.
If you go to this site and read the manual online go to page 28 it will tell you what thread to use with what fabric. It would not let me copy/paste
Scroll past the "download the document" go to "table of contents" click on view all then scroll down to fabric/thread/needle combinations click on it and it will bring you to the page.....
http://www.retrevo.com/pdf/18806dj992/30/FABRIC%2C+THREAD%2C+AND+NEEDLE+COMBINATIONS#q=Brother+XL-2600
Essentially
60-80 weight thread for medium and light weight fabrics
50 for heavy weight
50-60 for stretch
30 for top stitching
hope this helps lew
Feb 10, 2011 | Brother XL-2600
I have just got a second hand Quadpower Gen 2600 generator no manual, what oil does it take and where can I get a manual!!
Jun 04, 2010 | General Electrical Supplies
How do i reset the change engine oil soon light ?
Emissionwiz is correct on how to reset the oil life monitor. Turn the ignition to accessory on. Pump the accelerator three times. The Oil Life Monitor will flash for about 5 seconds indicating it has been reset correctly.
The oil life monitor is a function of the Powertrain Control Module (PCM) that tracks operating temperature and engine revolutions per minute (rpm). Obviously since the light came on again the temperature is too high for the engine rpm. The incorrect oil weight or type could have been used and you need to change it with the correct weight and type. The other possibility is that a sensor or the PCM has a problem and you will need to have an OBDII code scanner to identify the problem. That will cost you around $70.00 if the mechanic knows what he is doing he can tell you the problem. I think changing the oil with the recommend weight and type again would be the cheaper route.
Apr 01, 2010 | 2000 Buick LeSabre
What kind of oil should I use in Florida. Truck leaks a lot.Would a heavier oil help with limiting leaks?
You could use a straight weight SAE 40 or 50 in a warm climate like that. The heavier oil shouldn't run out quite as fast.
Dec 04, 2009 | 1990 Dodge Ram
Oil capacity and weight of oil
If it comes with a Briggs & Stratton 3.5 HP series 93400 engine, then the oil capacity is 20 fl oz (0.59 L). Hope this helps!
Sep 20, 2009 | Coleman Powermate Powermate 5000W...
Wht weight oil does a 5700 take?
allot the generators take 30 weight but thats a guss in the winter i had go with light weight.
i am on my second colman i lived woods for years with no electrci other generator 30 weight is heavy stops less wear tear on the insides. But winter time comes i had go lighter becuse oil was like malassas. And then i could not pull it to start it was so thick and heavy the oil in winter
go there web site look up ore try 1800 number for them to get
Jul 28, 2009 | Electrical Supplies
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
