Question about Toro Lawn Mower With Toro Power Tools
My mower starts but just putts i tore the carb off and cleaned it out even the jets an blew it all out but does the same could it be the rings
5 Suggested Answers
SOURCE: 2006 toro,,tecumseh 6.5...prime,pull cord, starts,
Morning,, yes I did find the problem.. previous person that worked on it installed the main jet tube upside down. The Red one with the two "O" rings on it. I cut off the crimped end and opened the hole and reinstalled it and it started right up.... Thanks anyways....
Posted on Jun 12, 2009
#1 Taper
  • 1041 Answers
SOURCE: Mower will start then starts to putt then cuts off
You will need to disassemble the carburetor and spraywith carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals and/or the jet in carb. These portals canbecome blocked. Replace the diaphragm as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 19, 2009
Grumman_1
  • 12 Answers
SOURCE: Toro 6.5 Tecumseh Recycler won't stay running
I have the same mower and problem. Found out the issue was the carburetor. Pull the Carb and do a quick cleaning. Order the replacement kit prior to working on. My bowl o-ring was shot and I couldn't get a seal after cleaning it out.
Posted on Jan 18, 2010
kel1guy2002
  • 3740 Answers
SOURCE: toro mower quick running after
Hi and welcome to FixYa. First off having worked in lawn mower shops personally you should take your mower back to the shop you had it repaired in. What you have is what we in the biz call a repeat disrepancy. Most likely there is a fuel supply problem if the jects have been cleaned. The problem can be:
1. Debris in the bottom of the fuel tank.
2. Clogged fuel filter
3. Float needle and seat is not opening fully or there is debris in the needle seat.
4. Clogged or pinched fuel supply line.
That is about it but I am telling you the repair shop owes you a free labor fix for this. You may have to purchase a needle and seat for around $5 - $6.00 and or the cost of a new fuel filter but, they certainly should eat the labor.
Thanks for choosing FixYa.
Kelly
Posted on Sep 18, 2010
Lawn Mower putt putt when filter in place
Your air filter screw may be too long from over tightening air cleaner and crushing the cover. It warpes the carb allowing for gas to leak into carb. Grind or cut off screw alittle or put washer on and don't over tighten. thank you for using fixya.
Jun 12, 2013 | Briggs & Stratton Garden
2005 suzuki wont stay running, i had just bought it and it will start but putt around but cant reach high rpms. does the carburetor need to be cleaned?
Yes
Remove the carb from the bike.
Completely disassemble the carb
Soak all jets, needles, springs, screws and carb body in a carb solution overnight.
Do Not soak any o-rings or the float. Clean the float with a brush, and replace the o-rings if they are flat.
Rinse with water and then blow everything out with compressed air.
Make sure you can see through the jets and the small holes on the side of the jets.
Make sure you blow through every hole in the carb body.
Reassemble carb, mount on bike.
It will run like new again.
NOTE: When removing the air/fuel mixture screw, turn it in(clockwise) until it stops and STOP turning, Do Not try to tighten any further.
Count the number of turns it took to stop. Write it down so you dont forget overnight. Remove it for cleaning.
When you reassemble the carb, turn the air/fuel mixture screw in until it stops.
Now turn it out(counterclockwise) the number of turn you counted.
If your not sure turn it out 2 turns.
Dec 12, 2010 | 2001 Suzuki DR 200 SE
Cleaned the float bowl which was dirty, blew out the jet, replaced old gas - still runs for 5 seconds and then quits.
You need to take the carb off and clean it out real good.i would suggest soaking it in mineral spirits and blowing it out with air.take a bread tie and strip it.then you can take the tie and clean the passage way,s in carb.if that don,t work try rebuilding or replacing carb.I hope this helps.Dale
Sep 12, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
My gs 700 will not start i tore the carbs apart and cleaned the jets and still nothing i put carb cleaner starting fluid and still nothing
the gs700 has mikuni carbs, right? These carbs have a rubber fabric diaphram and o-rings, when you tore the carbs apart did you make sure to remove all rubber and plastic parts, all the jets have o-rings that would have been ruined, the plastic throttle/choke linkage should have been taken out. NEVER USE CARB CLEANER OR STARTING FLUID IN A MOTORCYCLE CARB. there are to many rubber parts. the rubber diaphram alone can run over $100.00 each. for the correct o-rings and gaskets I found ebay to be the best place to shop.Also, one of the characteristics of a suzuki in that era is they won't run right without the factory airbox installed. That cost me lots of time and money finding that out, lol.
Aug 02, 2010 | Suzuki GS 750 Motorcycles
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Jim
Jun 14, 2009 | Toro Lawn Mower With Toro Power Tools
Surging
Doesnt sound like governor issues
Sounds fuel related
You need to remove your carb. and tank assembly as one
Take the carb off the tank and replace the daiphram& gasket between the two
note how the old one came off.
Sometimes the common fuel we have now with 10%ethanol effects rubber parts and causes them to fail prematurely.
you may notice the old gasket is wrinkled and maybe not pliable like it should be.
while you have the carb apart give it a fairly good cleaning with a air hose
be sure not to overtighten the bolts that mount the carb,back to the tank.
Be sure your fuel you are using is fresh
hope this helps some for you
Jun 13, 2009 | Parks Optical 13.5hp Briggs And Stratton...
2006 toro,,tecumseh 6.5...prime,pull cord, starts, then quits...just rebuilt carb, main jet,red plastic, two o-rings,,new bowl cover o ring, repace gasket on main bowl jet, i cleaned it all, blew out all...
Jun 11, 2009 | Toro Lawn Mower With Toro Power Tools
Champion Vantage 35 - mower will not keep running
More than likely the jet in the carb is somewhat clogged. Did this just happen after sitting for the winter? If so, start the mower and when it starts to die pump the primer to keep it running. Sometimes it will clean itself in a few minutes. If not, carb cleaner or take the carb bowl off and clean the jet.
Hope this helps
Kurt
Pls rate the answer
Mar 20, 2009 | Champion International Champion& Small...
Murray lawnmower
you may just need to remove the nut that holds the float bowl, and inspect the nut itself, half way up the nut should be a little tiny hole in the side.
use a bread tie stripped of the plastic covering and unclog this little hole, then replace the nut , when that hole becomes plugged the main jet cannot get fuel for the venturi pipe, thus the mower will start and hit a couple times then die immediately, that may fix the problem
Sep 15, 2008 | Garden
Toro Lawn Mower With Toro Power Tools Logo
52 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
