Question about Kenwood Food Mixers
Kenwood A998 manual. I need to see in larger detail the uses for the cutting plates available on a Kenwood A998 slicer/shredder, The manual with the attachment is not clear. Thank you.
How do I install the shredder?
You need to access the accessory attachment point, it's behind the silver KitchenAid logo on the front of the mixer. You'll need to unscrew a set screw (black knob at the very front of the mixer head), newer mixers have a hinged cover, on older mixers, it just pulls out. Unscrew the set screw a bit and fold up or remove the cover.
Now you will see a hole with a hollow square shaft inside, this is where the various optional items attach to the mixer.
Specifically for the shredder, you will need to attach a slicing drum to the drive shaft provided with the shredder, insert it through the drum, and raise the little bar in the rear of the slicer assembly.
Insert the whole assembly into the front of the mixer so that the square drive shaft shaft fits into the square hollow in the mixer, then lower the little bar to lock into place.
Dec 31, 2015 | KitchenAid kitchen aid"" classic stand"
Do I need to remove the kitchen aid rotor slicer/shredder shaft after each use?
I do, because if you don't, it can rust into place and become very difficult to remove from the attachments. (I'm guessing you mean from the slicer attachment, not the mixer itself, of course it should be removed from the mixer after use)
Nov 24, 2015 | KitchenAid mixer 4176067 attachment shaft
How do you remove the cutting blade on hobart model 410
The disc in the middle of the blade unscrews. A glancing blow with a rubber mallet will sometimes break it loose.
May 31, 2010 | Hobart Food Mixers
Where can I get a copy of the instruction manual?
Where can I download a copy of Kenwood Chef A901 manual?
Angel-Sin
Jul 31, 2009 | Kenwood Food Mixers
Does anyone know the model number of a stainless steel bowl to fit the Kenwood Chef KM300/
The model number doesn't really exist other than the fact that the stainless steel bowl is available for just about every Chef made. My own KM300 has a stainless steel bowl for example that came as standard - it however is the same bowl you can order from Kenwood or EBay under the A701/A901 model - all bowls from Kenwood can be fitted on the Chef model with the exception of the Major model which is a larger and taller machine.
May 06, 2009 | Kenwood KM300 Chef Stand Mixer
Clicking noice in gears
A clicking noise is not indicative of a major motor issue with a Kitchenaid stand mixer. If the noise worsens or is accompanied with other symptoms, or if you are incredibly concerned with the development of clicking, I would suggest contacting Kitchenaid Customer Service.
Their toll-free telephone number is 1-800-541-6390.
Apr 04, 2009 | KitchenAid KP2671 Professional 6 Series...
I need instructions to use my new kitchen aid attachment
Hi. Basically all you really need to know is to start the machine at a slow speed, begin shredding, increase speed to a point where the machine is not labouring. Next time you use that attachment, set it for that speed. Different attachments and the foods they process load different stresses on the mixer. Always use a speed that is one step above/below the labouring sounds. Kitchenaid doesn't see fit to publish these instructions online as they do their other manuals. Another missed opportunity by Kitchenaid. You might want to check out the kitchenaid forum. one of these people just might have it in digital form. Good luck! ricardok45
If this solution has assisted you, please rate it. ricardok45
Mar 19, 2009 | KitchenAid Food Mixers
I bought the slicer and shredder set for the KitchenAid stand mixer, no instructions were in the box. What speed do I use the attachments on?
Your attachment speed will depend on what it is you're slicing or shredding. Begin at speed setting two and work up to the speed where the motor begins to labour, then reduce the speed by one notch. Always start too slow, then move up. If you find this solution usefull, please rate it. Good luck. ricardok45
Dec 05, 2008 | Hobart A200 Stand Mixer
I am trying to fix the dial on my hobart slicer any ideas
This is the deal jason,get a rubber mallet,mineral oil and a mapp torch.If you look at the guage plate this is the part that the meat/cheese goes on you will see 2 rods that connect it.Heat the rods up and put on mineral oil.Hit the guage plate down while turning the knob left then hit it up and knob to the right ,keep doing this and apply plenty of oil .It will be good as new!
Aug 07, 2008 | Hobart N50 Stand Mixer
Food Mixers Logo
200 people viewed this question
Top Kenwood Food Mixers Experts
jason
Oscar Netto
Oscar Netto
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
