10 year old top loading washer. Moved it out to clean behind. Now, when it reaches a higher spin speed, something is off balance and it jumps around. It is perfectly level.
    Genius:
  • 1,028 Answers
Be sure rear self leveling legs have dropped down properly lift up at rear and let drop or pry down jammed leg with screwdriver
Posted on Apr 27, 2008
Washing machine tub is banging into the side of the walls..what's the problem here
There are two possible causes for when a washing machine jumps and bangs on spin. Either the load is a bad one and unable to be balanced, or a fault is preventing the machine from balancing the load (or causing the motor to surge into spin when it shouldn't). This causes the laundry to be flung around inside. The occasional jumping around may not be anything to worry about, but regular or severe occurrences should be a cause for concern and can cause expensive damage to your washing machine if ignored.
Both these faults are less common these days because manufacturers have built in certain protections, but it's still something that can happen. To differentiate between the two, observe when the problem occurs, if it's during a wash cycle, maybe at random parts of the programme, it may have a fault which really needs an engineer to diagnose as these faults can be intermittent and tricky to diagnose. If it happens when it kicks into the fast spin the chances are it's related to the load inside.
Am I overloading my washing machine?
By out of balance I mean when the washer jumps or bangs quite violently. If the washer is just rocking about on most spins make sure it's on a level floor and that it is properly level.
If a load is out of balance you can often observe the inner drum swaying about or even thumping the sides of the casing a few times whilst it's trying to distribute the load prior to fast spin. Before a proper spin the drum should revolve slowly for a couple of minutes. This is called "distribute" and at this stage you may see large flashes of metal drum on each revolution where all the laundry has settled around the drum but there wasn't enough to cover all of it. If this happens the drum will be out of balance and either refuse to spin, or if allowed to spin may cause the drum to thump around and hit the sides of the casing.
The best way to avoid unbalanced loads in a washing machine
If you try to wash a bulky, heavy and absorbent item, the washing machine is unlikely to be able to get it to balance inside the drum. Or if you put just a few large towels or a heavy item in amongst some very light fabrics the heavy items could bunch to one side of the drum and the lighter ones won't be able to counter-balance their weight effectively. There should be enough items to fit all around the drum. If there's only enough to fill most of the drum, but a section is empty, then it can get out of balance on spin. If the items are all light, then this may not cause a problem. However, if some items are heavy, they may cause violent banging, or the washing machine out of balance detection may just refuse to allow a spin.
Make sure you fill the drum well. Counter to expectations, the worst violent spins are caused by under-loading - not overloading. Heavy bath mats are notoriously difficult to balance and should ideally be washed with other items or they may gather on one side of the drum. However, some people (understandably) don't want to mix the bath mats in with normal washing. If this is the case and you do get problems with the bath mats getting out of balance I suggest you use old towels or sheets to even the load up. With most modern machines though, a heavy bath mat is more likely to just not get spun rather than be allowed to spin out of control and wreck the machine.
Sometimes you can get an unbalanced load by sheer chance, with loads you have successfully washed many times before. The occasional bad load is inevitable but constant bad loads and violent banging on spin should be looked into. [ Related: loading the washing machine properly ].
Modern washers have built in out of balance protection
Most modern washing machines now electronically monitor the motor during the slow distribution section leading up to the spin. If the load is out of balance, the motor shouldn't be allowed to spin. Typically, a modern washing machine will attempt to balance the load a certain amount of times, or for a certain passage of time, but if it can't, it will either reach the end of the program without spinning, or it will abort spin and turn off. (both scenarios leaving the clothes wet through). Some washing machines may allow a slow spin if the clothes are reasonably balanced, but then unless they settle down, it will not allow a higher spin thus leaving the clothes spun, but much wetter than normal.
Some will indicate a failed spin due to being unable to balance the wash load so check your instruction book to see if your washing machine has this function and what happens if a spin is aborted. Unfortunately some washing machines do not adequately inform the user that it failed to balance the wash load and aborted spin. As an engineer, I have been called out many times because a load was washed but not spun, but there was no fault on the washing machine, just an aborted unbalanced load.
Extra large drums make balancing loads harder
These days you can buy washing machines with much bigger drums. The average drum size was at one time a mere 4.5Kg but is now 6Kg. You can buy washing machines with 7Kg, 8Kg and even 10Kg drums.
These washing machines can be more prone to refusing to spin some small loads because they need even more items to fill the drum. For example, my 7Kg washing machine will not spin 3 large towels. Last week my wife was extremely frustrated with our 7Kg drum washing machine as she had just washed our son's hoody-top and wanted to spin it in the washer. It simply would not spin, so I advised her that it needed something to balance it out. She put in a couple of towels but still no spin. Eventually 5 towels were needed to balance out the absorbent top and allow a spin. This is a minor inconvenience compared to the benefit of being able to fit more washing in (even our king sized quilt) but it highlights how if you have a very large drum it could be more prone to not spinning small loads [ Washing machine won't spin just one item or very small loads ].
I'm loading the washing machine correctly but it still bangs and jumps on spin
This is unfortunately a difficult fault to diagnose. It could be various things including a faulty connection somewhere on the motor or pcb, especially if intermittent. It can be caused by a part overheating, cutting out and then cutting back in causing loss of control. If this fault isn't caused by the loading you really need to get an experienced engineer to look at it. Find a washing machine repairer on Washerhelp
If a brand new washing machine is jumping around on spin
Make sure you have removed all of the transit packaging before using a new washing machine. The transit packaging stops the suspension from working so without the tub being able to bounce up and down on the suspension all the movement created on spin will be translated to side to side movement and the washer will move about and shake.
Loading washing machine White Goods Help washing machine jumps and bangs on spin Washing machine won spin just one item Book washing machine repair
Aug 02, 2015 | Washing Machines
It drains very slowly and it makes a high pitch sound when it does spin...sometimes you hear something tapping or slapping, likesomething is stuck.
To me it sounds like you have something stuck in your pump. I would check that first. I had the high pitched sound during the spin cycle on my machine and it turned out to be the drum bearings. That part used to be covered by a 10 year warranty but not anymore. My machine was less than ten years old and it cost me around 300.00 to fix it. I have paid for my machine 3 times over in repairs. My next washer will NOT be HE and probably an old school Speed Queen
Apr 08, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Why ?
do u have the wash load balanced , I noticed this in a lot of washer problems , people just throw the cloths in the washer without balancing the load , this is something that must be done on every washer and load , you must do this every time you use it , hope this helps ,
May 19, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Whirlpool washer dryer not spinning one item
In fact there are sensors that can detect higher vibration and there by control the speed. It must be seen if this is available on your model. Please check the capacitor to the motor, couple a similar one and see if the speed improves. Also check for free movement with your hand , if not you need to reset the drive assembly.
finally check on the motor, check the drive.
Jan 20, 2013 | Washing Machines
Kenmore Elite oasis 2709 ol signal came up, initially sears repairman said that the drum needed to be replaced so they ordered one and about a week later it showed up, then I wait a week for service guy to...
The "liquid" you here sloshing around in there is supposed to be there,it helps it to stay balanced when it spins at Hightower speed. Also you should use the "clean washer" cycle about once a month,... It helps get rid of the hard water deposits that build up, unless you have a water softener unstaaled in the house - but most people don't. If you do a lot of laundry, the strut rods that hold the drum in place wear out( mine lasted six years) and that will make it out of balance when it goes into drain and spin cycle.
Oct 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
LG Tromm washer wont spin through the spin cycle and reads error ue. I have tried to balance the load several times and still get the same error.
This error generally happens when people try to run a bulky load, like a coat, rug, pillow, etc., using a high speed spin. For these loads, choose the low speed spin. After the cycle completes, if you think the clothes are too wet, power up the machine again but instead of choosing a cycle, just push the spin speed button until it shows the next higher spin speed (usually about 14 minutes will show on the display) and push start. The machine will usually be able to get to a faster speed now, as the clothes have some of the water spun out of them from the earlier low speed spin, allowing the machine to reach a higher spin speed without the Unbalance Error code showing up. Of course, you want to make sure the machine is on a solid floor with all the legs adjusted properly also.
Jan 02, 2011 | LG WM-1832C Front Load Washer
Maytag heavy duty top loading washing machine stopped and won't restart
remove console screws behind timer is lid switch if you have a volt/ohm meter with washer disconnected ckd switch operation also there is a fuse on same assembly ck it
Aug 17, 2008 | Washing Machines
Spin problems
this is the snubber ring it is under the transmission it means a total disassembly to replace
Apr 29, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
