Question about Homelite Garden
Need sparkplug gap setting for Homelite BX-90 Bandit Yard & Leaf Blower with 25cc 2-cycle engine?
  • 246 Answers
SOURCE: homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
bbreton
  • 437 Answers
SOURCE: BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Posted on Oct 14, 2009
  • 251 Answers
SOURCE: How do I adjust needle valves on a 25cc Homelite
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Posted on Oct 23, 2009
SOURCE: where does the gas lines on a homelite bandit leaf
two in the tank, and two to the carb.
Posted on Jun 28, 2010
  • 122 Answers
SOURCE: I have a old homelite
http://www.ereplacementparts.com/homelite-blower-parts-c-18807_18808.html
Posted on Feb 02, 2011
Homelite bandit bx 90, What is the fuel mixture?? Thanks
On the bandit, you are safe with a 40:1 ratio. In other words 8oz. of oil to 2.5 gallons of fuel.
Feb 12, 2011 | Homelite 'Yard Broom' Leaf Blower
I just bought a used bx-90 bandit and it runs great. The problem is that fuel oozes up thruthe top of the fuel tank right where the fuel line goes in. It runs down the side of the tank and all over...
Just replace the fuel lines they become hard and shrink allowing leakage. If your tank is like upper the part number is HM-0745499 or like lower part number HM-UP03825 or you can take to local small engine dealer and he will probably change cheaper than you can buy.
Nov 09, 2017 | Homelite 'Yard Broom' Leaf Blower
What is the fuel gas ratio for a homelite yard broom ll 170mph blower
The mixture should be at a 50:1 ratio, using Premium Exact Mix™ 2-cycle engine oil. If Premium Exact Mix™ 2-cycle engine oil is not available, use a high quality 2-cycle engine oil, mixed at a 50:1 ratio.
You can get the manual on the link below if you need it also.
https://www.dixiesales.com/ipl/338/ut08120b%20manual_254_eng.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Homelite 'Yard Broom' Leaf Blower
I have borrowed a small Homelite leaf blower with
If you go about 32:1 you will be OK. It may be a 40:1 unit, but better safe than sorry if you are not certain.
Mar 07, 2010 | Homelite 'Yard Broom' Leaf Blower
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
Spark plug
take your old one with you to walmart or an automotive store or hardware store
Jul 07, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite ut o8107 blower 25cc will only idle
Hello:
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
What is the spark plug gap setting for a homelite leaf blower?
Hello mackoshark:
Most Small Engines Use a .035in to .040in Plug Gap.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Apr 23, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
170 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
