Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
My Hoover Whisper Cyclonic is collecting the dirt but not taking it into the cylinder. The brushes were at one point starting and stoping due to the belt periodically turning,now the brushes are turning and the dirt just collects and I'm starting to smell a an oder like rubber burning.I've taken it apart and tried to make sure the is no clog. The one hose that I can't check is in the back right base, above and left of the right back wheel.
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
You need to change the belt once every year. It's a good idea to take it to your local vac shop and have it serviced once a year also. They can fix this for you. Your belt is worn out.
Posted on Jul 03, 2017
SOURCE: Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Posted on Mar 18, 2008
ukvacfan
  • 328 Answers
SOURCE: dc11 dyson
I dont think its a problem with the filters if you have normal suction.
If the DC11 cylinder/ canister vac has an air turbine brush / turbo brush check that the drive belt inside it isn't clogged with dirt. If its a toothed belt ensure that it is properly snapped on as well as the other parts in that floor head tool. There may also be dirt clogged in the turbine wheel which is stopping the brush from moving quickly.
Posted on Mar 30, 2008
  • 37 Answers
SOURCE: Dirt/Collection Tank Bissell Little Green
no it doesn't come apart. you may want to soak after each use with hot tap water. sorry:(
Posted on Sep 25, 2008
  • 33 Answers
SOURCE: Eureka Capture Vacuum
1 ) That unit cannot shut off the airflow to hose while unit is used in upright position. The hose is in constant use, whether you are using attachments, or vacuuming the floor.
2) It does sound like you have a clog somewhere in the unit. Most often it is the grey filter screen is full, (which is located just above the dust cup...instructions found on sticker on back side of dust cup) which causes everything to clog or back up. You should check this piece every time the dust cup is emptied.
3) To check for clog in main hose, remove the square clear hose adapter (with a phillips screwdriver) from the back of the unit and pull out the grey plastic attachment end of hose from the side of the unit by the duster, and unwrap the longest part of hose from vacuum and lay it on the floor. Get a quarter or a nickel and while holding the clear square adapter end of hose up , drop the coin into the hose, shake the hose to see if the coin will roll all the way out the other end of hose onto the floor. If it comes out, re-attach the hose adapter , making sure the little foot is in place, and with the dust cup locked in place, turn the unit on, test suction at end of the hose, it should be strong. But, if itdoesn't come out, there is a clog. The grey plastic hose retainer at the bottom of the unit is open where you can stretch it over the hose and free the hose from the unit.Take something like a mop handle or broom handle,(I've also found a long dryer lint brush to be helpful) insert into the hose to break the clog loose. Repeat the coin test. When the coin comes through, reattach the hose.Test for suction.
4) To test the lower portion of hose for a clog (from the duster unit to the brushroll area in base) with the attachment end of the main hose out of the hole, you should be able to look down the opening and see into the lower portion where the hose curves into the base. Drop your coin in the opening (not in the duster tube) it should, with gravity, roll out to the floor. However, it may stop at the brushroll, so tilt your unit forward, and side to side to see if it comes out. If that doesn't make it come out, there is a clog in that lower hose.
5) To clear the clog, recline the handle all the way down on its back( again like vacuuming under a bed) roll the unit on its "belly", you should see the lower hose straighten out more, Insert something blunt into it, broom handle, or a bent wire coat hanger (bend to protect hose from puncture) and you should be able to clear the clog. If it still wont clear the clog, remove the 4 screws from bottom of unit and take hood of unit off to see the opening of bottom end of lower hose, near the brushroll. Clean out clog from that end. Once cleared, stand unit upright, re-test with the coin until coin rolls out freely. Put all parts of unit back together.
6) Make sure the height adjustment pieces are still attached to bottom of unit. (the plastic piece with 2 wheels and a spring) Reset this component, by reclining the handle in normal operating position, lean down turn height knob on hood to the highest carpet setting, and flip it slowly over to the bare floor setting, do this back & forth 4 times... over & back is 1, etc...then determine your carpet height...( berber is like normal carpet ) set the knob (with handle still reclined) on the middle setting, then place unit back in upright position. Test the vacuum for approx. 1 minute. While testing the unit, look into the dust cup and see if the dirt is swirling. If it isn't, then check the dust cup filter,(under the dust cup) to make sure it is clean. If it is coated with dirt, etc...,remove the filter tray , pinch the foam filter and pull out of tray.Tap the filter over a trash can, or replace it if you have a replacement foam filter handy. Replace foam filter in the tray, replace filter & foam into unit, close the lid, replace the dust cup and lock in place. Re-test vacuum.
7) If all the above steps are followed, this should prevent future clogs in unit.
Posted on May 17, 2009
ThinkVacuums
  • 144 Answers
SOURCE: My hoover windtunnel + cyclonic will not pick up
check the belt of the brush roller. Or check for a clog
Posted on Mar 16, 2010
How am I suppose to emty The uh70060I feel that I am not getting all the dirt out. Can the red top be removed?
Hi! It is not recommended you disassemble the red cyclonic filter. You may use your upholstery brush or something similar to brush off the cyclonic filter. You may also wipe it down with a damp cloth. Do not rinse or submerge the cyclonic filter in water. Hope this helps!
Jul 09, 2014 | Hoover UH70060 Bagless Upright Cyclonic...
Hoover zen whisper multi cyclonic canister vacuum belt removal
just underdo the screws from the bottom of the hoover head (where the brush rotates from) I think from memory there are about 8 screws carefully price the plastic apart use a flat headed screwdriver as sometimes there are retaining clips and you should be able to access it hope this helps
Apr 05, 2014 | Hoover Zen Whisper Multi-Cyclonic Canister...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Brush doesn't spin and there is no suction there either, the brushes move freely when manipulated manually
Check for clog in the hose or what ever connects the nozzel to the collection device. I pick up vaccum cleaners all summer, most new, all clogged, all from the trash.
If possible, take the machine outside, open the collection device, run the motor. Is there suction you can detect anywhere?
Sep 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover f5915
Since the Steam Vac does not have any belts... the logical issue is Switch setting (Hi, Low, Off) on the base cover. The only other is dirt collection on the air intake for the brushes (unit uses air passing over plastic fan blades to spin the brushes). To clear the dirt problem, remove the clear plastic cover located just in front of the brush Switch. You can now use your finger nail (or an old tooth brush) to clean the filter screen located just below the Switch. Don't tear it, just gently remove the accumulated dust/hair.
Brushes should spin once you reassemble and power it up!!
Aug 14, 2009 | Hoover F5906-900 Upright Steam Vacuum
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Dc11 dyson
I have taken the brush heads off and pulled all the hair out of the small gap between the chrome shaft and the plastic gear housing. Then a small amount of 3-in-1 oil into that gap to lube the internals and just a little through the air intake on the side of the head to clean and lube the seals and it works like new. This lasts about 9 months under high use and the process takes roughly 10 minutes.
Mar 30, 2008 | Dyson DC11 All Floors Bagless Canister...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
484 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
