Power supply problems on an Astar LCD tv~model no.LTV-32HBG.On the power supply board no.7506T2627001AP;I found four capacitors:two(2)680mf/25v and two(2)2200mf/10v;these capacitors became defective I believe,due to two defective transistors-Q3 & Q15.The transistor number(on the component)is:40N03GP and I have tried to cross reference this number but had no success.I need a good reliable replacement transistor(x2) that will substitute for Q3 & Q15,ie;if the original part is no longer available.Thanks!
  • richardstvpc Aug 10, 2010
    yes, thanks guy!
  • 11,800 Answers
Transistor's datasheet
http://www.alldatasheet.com/datasheet-pdf/pdf/146842/A-POWER/AP40N03GS.html
The part is widely available , you should be able to get it from your local hobby shop.
Posted on Aug 09, 2010
My tv has no power at all
U check the power source like the power socket outlet?U tries tv unplug,replug the tv back like about hour later see if the tv resetting itself back to the factory setting and work again.Same result after this ur tv still have no power at all than the tv have a dead power supply board.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Aug 31, 2011 | Astar LTV-32HBG 32 in. LCD Television
I do not even get a power on light when i plug it in.
Check the power source?Yes,the power supply board is dead,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 24, 2010 | Astar LTV-32HBG 32 in. LCD Television
WILL NOT TURN ON,BUT HAVE GREEN LIGHT
Astar LCD tv are famous using cheap capacitors in their power supply board as componnents,these capacitors are leaking gases,they bulges up,puff up.That why one ur tv is dead.The other tv is unstables changing channel on it own.U know basic electronics,and soldering?Take both of ur tv aparts.Searches all around the power supply board.Look for these bulges up,puff up capacitors,replaced these capacitors.Both ur tvs will work normal again.Or tries websites like Shopjimmy.com,Ebay.com to buy two whole refurbish power supply boards to replaced each one of ur tv.
Jul 09, 2010 | Astar LTV-27BG 27 in. LCD Television
Blinking power indicator light
When TV indicator light is blinking and after that the power will cut off. First you need to check the power board. But I am still need more details of your tv. please call 323-767-6030 and I will go through thes trouble-shooting, with you.
Mar 08, 2009 | Astar LTV-32HBG 32 in. LCD Television
Astar LTV 2701 power supply
I have aquired an Astar LTV 2700 and believe parts are missing. Any idea where I can get the Schemetics for this tv. E-mail me please. sonshinerider@yahoo.com
Oct 24, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar Power Supply
Fixing the internal power no problem depending the power board it's burn or not. second thing is your LTV-32HBG TV with one HDMI connection or two HDMI connection? I know more about these Astar TV because I have work for the Astar co as an electronic technician before and I only give out such information how to repair these tv. so, call 323-767-6030 and I will help you go through with you problem by the phone.
Mar 18, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Power supply repair
I just finished replacing all 25 or so of the electrolytic capacitors on the power supply board of an LTV 2701 AStar TV. When I got done, the tv came back to life and WORKS GREAT. Every last electrolytic was either leaking onto the board or puffed up or both. The main problem is that Astar designed the case so that no air can circulate over the board and the capacitors bake after a couple of years. If you don't do somethig to let the air circulate, you will be replacing them again in 2 more years. The board is pretty sturdy however and its fairly easy to replace them all with some copper desoldering braid and a 125 watt soldering gun. Just be sure to keep the polarities right on the electrolytics and make sure that they are the 105C variety. Good luck and remember to add some fans and cut some extra holes in the cage.
Jan 23, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Screen goes black immediately after astar logo screen comes on
Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 21, 2008 | Astar LTV-3001 TV
Astar Plasma
I had the same problem... Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 13, 2008 | Astar LTV-3001 TV
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
