Question about Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual
Nortrak 4100i wont go up or down - Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Hold down stop and speed + then put safety key on
hit stop once
push incline+
let it go up and down
take key off and reattach
try
if it still doesn't go the incline motor is bad
Posted on Aug 11, 2010
I have a nordic track 4100i treadmill.
1) Faulty sensor speed try to adjust it face to face magneto motor
2)Sensor speed try to tight the connector very well.
3) Replace if neceesary.4) Main motor faulty or burn. Test 115vac for input measure without load fore easy running.
5) Test the main motor controller board for 115vac input and output for +5VCD,
6) Adjust the deck bel for 2-3" for lift max.
7)Lubricate the deck bel.
8) Test the transformer for input and secondary voltage.
See the block diagram for illustration how the main motor controller has 90% aprox of function of any treadmills.
sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Dec 20, 2011 | Nordic Track Nordictrack Apex 4100i...
Hello, WE have the model 4100i treadmill and the elevation is stuck in the highest position and won't reset to zero. How do I fix this or who can I call for this repair? Thanks, Tom
Try the calibration procedure found in the troubleshooting section of your manual first. Here are the basic instructions.
With the key in the console, press one of the Incline buttons. While the incline is changing (or the numbers on the console) , remove the key. After a few seconds, re-insert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. This will recalibrate the incline.
If it still doesn't move, remove the cover. Find the incline motor. You will see a slot in the end of the motor. Using a drill with a standard slotted screwdriver bit, spin the motor counterclockwise (if it is having difficulties spinning, turn clockwise instead) for just a couple seconds. Now do the calibration procedure again.
I have had machines that got stuck before. Once released and recalibrated, the operation was OK.
The service number for your machine is found on the model number sticker on the frame of the treadmill.
Feb 26, 2011 | Nordic Track Nordictrack Apex 4100i...
Need new endcap for apex 4100 NTTL#18903
Sorry to inform you, that part is no longer available from the manufacturer.
Our Nordic Trac Apex 4100i will power up but the keyboard does not respond to different key presses and the incline is stuck part way up. We ordered a power supply and replaced the original one. That did...
You can try and do a re-calibration on the treadmill (Its listed in the Users Manual) but it sounds like the console has gone bad. To repair this you would have to replace the entire console.
Aug 21, 2010 | Nordic Track Nordictrack Apex 4100i...
Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
Own a Nortic Track apex 4100i. Great treadmill.
You need to have the power supply board rebuilt with larger Caps and resistors. Look on the internet under treadmill repairs. The board is easy to replace yourself so don't have someone come in and overcharge you. I think about 4 screws and two plugs.
Feb 10, 2010 | NordicTrack E4000 Treadmill
Where can I get a key to fit the Nordic Tract Apex 4100i
Go to Nordiactrac.com and enter your Model number from the sticker on the frame. It should read NTL or NTTL then 4 or 5 number. Folow the instructions and ask for the Part's List. You should be able to find it there.
Jul 07, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual Logo
250 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
