Question about Canon PIXMA iP90v Printer
Paper will not feed and cartridge making grinding noise
yooperbud
  • 8637 Answers
SOURCE: Can't change Cartridges paper won't feed
Normal 0 Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
  • 523 Answers
SOURCE: cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Mar 11, 2009
SOURCE: cartridge jammed grinding noise
I just did a cleaning.
Posted on Apr 29, 2009
SOURCE: displays error 5100
hi there... the error code can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. - get to the purge cap (the white sliding mechanism that the print head parks to when it's not in use) .. its likely its not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps you out.
regards iversh
Posted on Sep 19, 2009
pineworks
  • 4041 Answers
SOURCE: canon mp830 errors 5110 and 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
My hp laserjet m1522nf makes a grinding noise and then says add paper' it also makes the same noise when i shut it down and power it up again ... does this mean the printer is garbage?
it could be a bad toner cartridge
try replacing each toner cartridge one by one to see if grinding gear noise goes away.
Or
it could be jammed paper somewhere inside the printer
Feb 03, 2017 | HP Laserjet M1522nf All-in-one Laser...
Keep getting out of paper error and paper wont feed makes loud grinding noise
A screw or something else is in the printer not allowing the gear to move freely.
Apr 22, 2015 | HP C6280 Photosmart All-in-One Printer...
Why is my printer making really loud grinding noise and will not feed paper or print
It sounds like a bit of paper is stuck somewhere in the paper feed route. Remove the toner cartridge and any other bits that pull out. Removable bits often have a green tag or finger grips moulded in to them. Do a careful check in the printer for any bits of paper or even a full sheet stuck somewhere. Carefully remove all rubbish and reassemble.
Dec 01, 2014 | HP LaserJet 1018 Printer
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Nov 26, 2008 | Epson Stylus Photo R300 InkJet Printer
My printer, makes a grinding noise, when the paper is feeding through when printinig?
Look to make sure that there isn't a small bit of paper caught in the wheels that push the paper through. Over time, even a small bit in the corner can destroy your printer.
Mar 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Canon PIXMA iP90v Printer Logo
old marine
old marine
