Question about Kenwood KVT-512 Car DVD Player
Put pictures on a kenwood kvt-512 - Kenwood KVT-512 Car DVD Player
SOURCE: kenwood kvt512 code
forgot my code how can i reset it
Posted on May 16, 2009
SOURCE: need installation instructions
do you still ned the intructions on how to install your kenwood kvt-512??
Posted on Jun 15, 2009
  • 4 Answers
SOURCE: Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Posted on Jul 16, 2009
  • 23 Answers
SOURCE: Code set for a Kenwood KVT-512
Use KCAR for the code.
Posted on Aug 24, 2009
SOURCE: password code for kenwood kvt-512
The password code is something you set yourself by going into the settings. If there is a security code already set up it is because: A) you bought it used and the previous owner set it up...just ask them, or B) It came new from the factory with this settings error...call kenwood, or the place where you purchased.
Posted on Aug 26, 2009
I got a kenwood kvt-512 and my ipod seems like it doesnt work ?
go to :- http://kenwood.com/cs/ce/mm/firmware/2008/eng.html
then change the file to an iso and burn to a disc.
put the disc into stereo and press dvd and let the disc do the rest.
hope this helps works on all kvt systems
Dec 31, 2010 | Kenwood KVT-512 Car DVD Player
KVT-512 Car DVD Player: Battery was disconnected ans car stereo locked out...
Sorry...KENWOOD codes are only available from the Main Dealer or a Radio Decoding Service
May 17, 2010 | Kenwood KVT-512 Car DVD Player
I need the site for kenwood kvt-512 update
try this I use this for getting user manual or leave them a question Good Luck!!!!
Techman
http://www.kenwood.ca/Support
May 14, 2010 | Kenwood KVT-512 Car DVD Player
How do I change the background on my kenwood kvt-512
Check one DIY in this link: dyi-background-change-kvt-512-a.
Hope helps (remember to rate this answer.
Nov 18, 2009 | Kenwood KVT-512 Car DVD Player
How can i get my kenwood kvt-512 or kvt-512 multiregion player. it only plays region 1 dvds but how can i make it multeregion, thanx a lot
This is basically a hack. Type into the web address bar http://www.dvdhacks.co.uk/ enter model number then follow instructions
Jun 15, 2009 | Kenwood KVT-512 Car DVD Player
Does anyone knows where to conect the dimmer wire of a kenwood kvt-514 or kvt-512??
Connect to the side light live. So when you turn the lights on it dims the display.
Kenwood kvt512 code
Jan 27, 2009 | Kenwood KVT-512 Car DVD Player
Need installation instructions
Nov 20, 2008 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 Car DVD Player Logo
56 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
