Question about Socket Communications Decal For Kobalt Impact Wrench Set Air Tools Box
Kobalt air compressor starts and stops after maybe a second or less. Need to reset my wall outlet every time it stops.
    Problem Solver:
  • 5 Answers
Sounds like it is drawing too much power. either the breaker isn't sized correctly or the motor has a bad winding causing it to draw too much amperage. remember, electric motors draw up to 3 times the juice briefly when starting up
Posted on Oct 31, 2010
Where to get a circuit breaker for a 2hp 5gal kobalt air compressor
Such equipment is mostly of generic far-Eastern manufacture and few spare parts and even less information tend to be available.
Such spare parts as are available tend to be either parts salvaged by the dealer from returns or generic parts which aren't always exactly interchangeable. By circuit breaker I assume you mean the pressure start/stop/isolator switch? Ask the seller who might say no (not surprising).
You might find a similar switch on ebay. Switches on larger higher quality compressors do the same job but if you have to resort to buying one of those you could discover a new compressor is cheaper.
Mar 28, 2016 | Air Tools & Compressors
Kobalt gravity spray gun and I have a little air that comes out constantly. Why is that and how do I stop it? Thanks
You must be using a "turbin" which is different and better than a compressor however a turbin runs all the time and air must escape from it unlike a compressor with an airtank the shuts off after the desired pressure is reached it shuts it self off then turns back on with tank pressure drops below what you have set it at- a turbin reaches the pressure you set the regulater at and maintains it constantly NEVER STOP THE AIR FROM PASSING THRU IT in fact a lot of times i do this to remove any dust i may have missed so evrything is working like it should on yr sprayrig..
perry tradesman
Oct 19, 2014 | Kobalt Large Gravity Feed HVLP Spray Gun...
My kobalt 80 gallon air compressor won't turn on
BE CAREFUL! Jump the pressure switch and see if it starts. If so, replace the switch. If it doesn't start but hums, cut the power and try to turn the compressor by hand. Free it up if possible. If it does not hum, look for a reset on the motor or a blown fuse or breaker.
Dec 14, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
Need kobalt work bench assembly instructions
I have been repairing compressors major brand Rol Air, Dewalt, Porter Cable, Jair, Jenny, Emglo, etc. and find, even with major brands,very limited information on assembly instructions. I havent seen any material on Kobalt, however find that their compressors are very much like the oil-less from cambell hausfeld, dewalt and porter cable. Parts are available on the net. The major problem that I see is that there is no easy / reliable way to install the drive belt. Without proper procedure or tools, the belt will tear. For the most part, you are on your own to experiment on repairing them. You can re-post a specific question on the Kobalt and I will try to answer. Good luck.
Nov 10, 2012 | Air Tools & Compressors
What oil should I use if Hitachi oil isn't avalible?
On your next trip to Lowes look for Kobalt air compressor oil in the tool department. It sells for under $3 and works great for normal use. They also have Kobalt synthetic compressor oil for extreme conditions and longer use between oil changes. Sell for about $7. I also used Hitachi synthetic oil #19210b 8oz about $8 but hard to find. Kobalt synthetic costs less and works. Good luck.
Aug 02, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Problems with kobalt air compressor 26 gal. simply would not start
Check and reset motor thermal overload (red button) on motor, also check circuit breaker for your power supply. other than that the pressure switch is what stars and stops the motor, and depending on your level of knowledge you will need to check continuity through the pressure switch with a ohm meter.
Jan 20, 2010 | Air Tools & Compressors
CH 4 ga double stack compressor electrical reset
This is two problems. recycling without use means there's a leak: start er up and spray air connections lightly with window cleaner, watch for bubbles to locate leak. Keep moisture away from any electrical areas. Tighten any loose connections until leaks are no longer present. I have had simular problems. I am assuming that you do not have an oiless compressor. First I changed my oil to full synthetic purchased at the auto parts store. Use the same weight called for by the owners manual. Then I try to always use a 20 amp circuit to run my compressor. I can now run off a 20 amp circuit with a 10 guage 50 foot cord.
Sep 15, 2009 | Campbell Hausfeld 04 Gallon Twin Stack...
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Socket Communications Decal For Kobalt Impact Wrench Set Air Tools Box Logo
268 people viewed this question
Top Socket Communications Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Socket Communications Air Tool and Compressor Expert? Answer questions, earn points and help others
